I am trying to find the coolant temp sensor on my 2002 TDI. The diagram from the parts house shows right side of motor in a hose that I can't find. Can anyone tell me where this sensor can be found. A picture would be worth a million. Is it hard to change out?
Here you go!
Facing engine low right side between firewall and engine. Look here, picture taken between firewall and back of engine! Newer Coolant Sensor In order to get a good look at the sensor locaton you may need to remove your air filter box, etc. HTH!
Central Florida TDI Club Wife's 2005 manual with RC1+ Rocketchip just sipping Beetle Juice 47.5 MPG Avg on Fuelly.com. Ross Tech Vag Com! |
wow, those pics were super helpful. Found mine as soon as i took the air box out. Pretty easy to change out, just remember that it is a plug and the moment it comes out so does the antifreeze so do it quick!
I had my check engine light come on and my scanner told me it was the engine coolant temp sensor. Changed it out and so far so good. I don't know why but it seems like the motor is running smoother too. |
| Coolant temp sensor - | mrsbeazley | 2.0 Liter Gas | 27 | 05-09-2012 02:26 PM |
| Coolant Temp. Sensor -- which one? | brokedownbeetle | 2.0 Liter Gas | 15 | 06-06-2008 07:02 PM |
| 01 aph 1.8t coolant temp sensor 2 pin not 4 pin | tripen2 | Questions, Issues, Concerns, or Problems with the New Beetle | 4 | 10-25-2006 11:44 PM |
| Where is the coolant temp sensor? | DruzeTito | 1.8 Liter Turbo | 8 | 06-22-2006 02:35 AM |
| Coolant Temp Sensor | GaUdeNtiUs | 2.0 Liter Gas | 8 | 02-09-2006 10:14 PM |
