transmission - NewBeetle.org Forums
Old 11-24-2009, 10:09 PM
Default transmission
We just bought a 2002 beetle diesel4speed automatic,the transmission had been replaced with a rebuilt from aamco transmission.It sometimes seems to start out in maybe 2nd and then won't go into 4th or drive. Is there any computer up grade or what could be the problem?I stopped the other day and shut off for a minute, then it worked OK.I need help!I had it put on the machine today . Code said no connection to speed sensor!Parts house said there are two different ones! One in front or one in back of motor. What do I look for?Thanks,Rick
Old 11-25-2009, 12:04 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Unfortunately I do not have any good news for you. These automatics (particularly paired with the TDI) are not good units at all. Rebuilds, even when done by a competent shop (which AAMCO chain shops are not), simply do not last.
The only viable options for these transmissions are replacement with a VW unit, which costs $4800 or so just for the transmission, or swapping it out for a 5 speed. 5 speed swaps usually run $1000 to $1500 parts and $1500 labor. I got lucky and got my parts for $600, but I spent another $600 on a beefier clutch to allow for engine mods. I will be doing all the work myself, so I will only be into it for about $1200.
You could get it scanned for codes with VCDS (generic OBD scanners do not work well) and see if anything has been noted by the ECU. What you describe sounds like limp mode, which could be caused by a speed sensor fault. If that is the case, you may be able to keep it going for awhile. But it could be something far more serious.
Just consider yourself warned that you may be in for some more serious repairs in the near future. Don't feel bad, you're not the only one. I have been afflicted with this transmission as well...it is going away very soon. Its a shame really, because the rest of the car and the engine is really great.
2000 New Beetle GLS TDI
Old 12-16-2009, 12:19 AM
TX, USA
Car: 2002 New Beetle TDI
I'm not 100% on this but the one under the battery is for vehicle speed (G68) and one in back is for transmission vehicle speed (G38). I'm getting that from my Bentley manual. If you are on TDIClub, email CoolAirVW. He's an expert and the only guy that won't tell you to swap in a 5 speed manual. I should know. My 02 TDI Beetle also has automatic problems but I won't be putting in another automatic.
2002 Cyber Green Slug Bug TDI SOLD
1996 Passat Wagon TDI (daily driver)
2011 Honda Accord (wifes car of course)
Is my transmission out? VW_Lover89 Transmission Talk 2 07-02-2009 05:01 AM
Need help with transmission? nclaw110 Transmission Talk 3 07-01-2009 08:11 PM
I need a new Transmission Pan 04BabyBlueVert 2.0 Liter Gas 2 02-12-2008 11:00 PM
Transmission BeetleBug99 Market Place Archives 0 10-21-2006 06:17 PM
DSG Transmission? Maggadog Transmission Talk 20 07-27-2006 02:40 AM
