speed sensor for transmission - NewBeetle.org Forums
Old 12-04-2009, 04:08 PM
Default speed sensor for transmission
Took to garage ,they put machine on it said that the speed sensor code read no signal. It want's to start out in 2nd and then I have no overdrive. I can shift it manually, it has 1st, 2nd and 3rd but no overdrive.Can I change the sensor? Were would it be , is it on the out side of motor or transmission?What does it look like?They told me 2 1/2 hour's to change.I checked at part's house only about $50.00.Thank's for any help.Rick
Old 12-04-2009, 06:31 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Depends which sensor:
01m - TDIClub Forums
What was the code? If it is the G68 sensor, the mount has to come off the transmission. The bolts that hold the mount to the transmission, and the other mounting bolts are all one-time use stretch bolts and will have to be replaced.
2000 New Beetle GLS TDI
Old 12-04-2009, 07:45 PM
Default speed sensor code
Code read 00297 no tss signal
Old 12-13-2009, 12:27 AM
Default trasmission
We found the problem! The code came up g38, was sensor on trans, wires were pulled out of it . Got a used sensor from junk yard ,works GREAT NOW! Thanks
02G / GHE VW 6 Speed TipTronic Transmission sledge0001 Parts and Accessories 12 05-15-2009 05:20 AM
2.5L 5L 6 speed manual transmission? brycastillo 2.5 Liter Gas 3 03-23-2008 03:55 PM
2.5L 5L 6 speed manual transmission? brycastillo Transmission Talk 0 03-23-2008 01:30 AM
6 speed transmission swap?! jezter Transmission Talk 0 02-19-2007 01:59 AM
