Warming up in cold weather - NewBeetle.org Forums
Old 12-19-2009, 12:30 AM
Default Warming up in cold weather
How do you appropriately let a TDI warm up in cold weather? I have seen on a few sites not to allow these TDI's to idle
Old 12-19-2009, 12:39 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Drive it.
Don't flog it while the blue temp light is on.
Drive normally after it goes off.
'02 & '05 Acura RSX
Dodge Cummins, Ford Ranger
M151 Ford
Old 12-19-2009, 12:45 AM
I do not flog it while that light is on...but is it okay to let idle for 15 mins prior to leaving as you would any other diesel
Old 12-19-2009, 02:29 AM
Tumwater, WA, USA
Car: 2002 Black TDI
No. just start it and drive under 2500 Rpm, that's what i do. from what i've read, idling doesn't allow enough oil to get up in the turbo and the engine is so efficient that it doesn't heat up. you could idle for a while and not warm it up enough to get the blue light off.
TDI FAQ
Old 12-19-2009, 03:42 AM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
15 MINUTES?!?!? Sorry, but that's just wasting fuel and it could be bad for your engine. Hook it up to a heater. I've never done that because I always park my NB in a garage.
Old 12-19-2009, 04:14 AM
oceanjoe89's Avatar
Perry, IA, USA
I've always been told to start it, let it run for like a minute maybe two (when it's really cold) and then drive it gingerly till it warms up.
Junior (My Car)
Jake (Me)
Old 12-19-2009, 07:43 AM
FarrisK's Avatar
Semi-Lurk Mode: GOOOOO
West Richland, WA, USA
Car: 2004 Ford Focus ZX3
The blue light goes off too early, IMHO. Wait for the light, then 3 or 4 more minutes.
Idling like you are all talking about gets the ENGINE warm, but does nothing for the transmission. When you take off, your engine is nice and perky, but the trans fluid is still cold and won't flow well. If you're hard on it, it can cause damage.
2004 Ford Focus ZX3
Drive more, worry less.
Old 12-19-2009, 04:33 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Nobody that I know of lets diesels idle for 15 minutes prior to use, not even big trucks. The only reason they idle for a little while is that they have air brakes and can't move until the air pressure is up to the minimum needed to release the brakes. The engine and drivetrain warm up better and faster under a light load.
Old 12-19-2009, 04:53 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Many modern diesels net LOSE heat at idle so cool off if left long enough, idling before moving off for 15mins can do nothing but harm IMHO.
Cheers
Simon
Old 12-19-2009, 04:54 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
How you treat it does somewhat depend on outside temp. When its 10 F or above I usually just start the engine, buckle up, check my mirrors, tune the radio and go and then take it easy for awhile.
If it is below 10 F and especially below zero, I will let it run until the idle smooths out and until the turbo changes tune a bit. The oil does need time to flow and you're not hurting anything by letting it idle for less than 5 minutes. Anything beyond 3-5 minutes of idling is ineffective and completely unnecessary as a cold engine does not really generate any heat at idle.
If you want easier starts and instant heat, get a coolant heater. FrostHeater.com - Welcome
2000 New Beetle GLS TDI
Old 12-19-2009, 05:37 PM
Czech (EU) NewBeetleClub
Pardubice, Pardubický kraj, Czech Republic
Car: ´99 1,9TDI Higline aka Colorado beetle
ALH engines in our cars has 3 special electric plug heaters in cooling circuit. So it warms a motor. But not transmission. You can kick it up, put off all the snow etc. and then drive. But best heat up is under small load as written up. But you do not harm the motor because it warms up by the plugs.
Old 12-19-2009, 07:06 PM
FarrisK's Avatar
Those aren't stock over here in the states.
Old 12-19-2009, 08:11 PM
DZLBUG's Avatar
I Am Breitbart
They are on manual transmission cars.
Automatic-equipped cars have the transmission cooler which sort of serves the same purpose.
Old 12-19-2009, 08:20 PM
FarrisK's Avatar
My manual didn't have one.
Old 12-19-2009, 08:29 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
i used to start mine, wait 37 seconds (enough time to buckle, turn on the seats, defrost to low, crank the radio, and light up the morning smoke), then drive off.
of course, if the windshield is iced, nothing i can do then for a few minutes except wait, so i'd go back in and smoke inside the house.
Old 12-19-2009, 08:31 PM
DZLBUG's Avatar
I Am Breitbart
Of course, you could have gotten your butt out of the car and scraped the windshield off. Ice takes forever to melt off when the engine is cold and idling.
I can assure you that it did.
Old 12-19-2009, 09:45 PM
FarrisK's Avatar
:smacksforehead:
I was thinking block heater that plugs into the wall, like a fullsize diesel pickup.
Old 01-14-2010, 02:18 AM
Default I warm mine up
I'm idling mine for 5 minutes or so before I start school runs at 7 am, when it's 20 degrees or less. If I don't I won't have any defroster as my breath condenses on the inside of the glass. The car seems to be happy with this treatment. My mileage has dropped to 40 or so, but it's only for a few months.
Old 01-14-2010, 12:49 PM
:smacksforehead:
They aren't just for big trucks! Picked one up for our Mk1 TD Been too cold to want to dig into the car to install it though. Oh irony!
Old 01-14-2010, 01:49 PM
MichelleRoze's Avatar
Auburn, Georgia, USA
I don't let mine idle long. I start it up, buckle up, turn on my music and then go.
Has anyone noticed that since it's been cold their engine revs high (like 1.5rpm) then goes down to idle? Never noticed it in the warmer months. Sounds like I revved the engine when I started it, then levels off to normal idle. Strange. Maybe cause it's cold and I have no muffler, I notice it more....
"Probie"
2k12 ToD Checklist
Dub Gestapo
Cold Weather v 1st and 2nd Gear D2Beetle Transmission Talk 9 02-07-2012 01:22 PM
Does Cold Weather Lead To Electrical Problems? wkjeepsrt8 Questions, Issues, Concerns, or Problems with the New Beetle 2 03-01-2009 07:21 PM
cold weather problem? rattle under the hood. callisto9 2.0 Liter Gas 9 01-22-2007 01:39 PM
Time/Temp readout blurred in cold weather? treblatsirc The New Beetle Experience 1 01-21-2007 05:50 AM
Casette deck error in cold weather yazny Car Audio 3 12-24-2006 02:36 PM
