Died on road #2 - NewBeetle.org Forums
Old 01-09-2010, 03:37 PM
Jonesboro Ar, USA
Car: 1999 Tdi
Default Died on road #2
I read the previous thread, my problem is whilst giving my Tdi some hard overtaking throttle the motor died. The timing belt is intact. motor spins over but wont start, there is diesel at the pump. This has happened before but if i backed out the throttle the car picked up again. Note this has only been happening since installing a bully dog programer!! I know I know but is there something valve or otherwise thats shutting down the motor due to over fueling? Can it be stuck in shut down mode? 1999 vw bug.
any ideas ?
Old 01-09-2010, 05:36 PM
Czech (EU) NewBeetleClub
Pardubice, Pardubický kraj, Czech Republic
Car: ´99 1,9TDI Higline aka Colorado beetle
Generally, buying bully dog programmer wasn´t the clever one idea I think. There are some issues why not to buy it. Better is real chiptunning with setting the values for your engine personally than gettin something between engine control unit and injection. Did you got it scanned by VAG or any other stuff? I would start there to see what´s going about.
Old 01-09-2010, 07:07 PM
Jonesboro Ar, USA
Car: 1999 Tdi
Yes got it scanned and no codes? I am going to disable the programer to see what effect that has.
Old 01-09-2010, 08:44 PM
Well, if no fault codes in computer, I think the only thing is possible. The programmer is sh** and it´s needed to be thrown away. Or just returned back ;-).
Old 01-09-2010, 09:52 PM
Jonesboro Ar, USA
Car: 1999 Tdi
Thanks for the great advise? how nice!
Old 01-10-2010, 06:05 AM
I am sorry for that. But I think that doing a serious chiptunning doesn´t mean just only adding more fuel. It also works with turbocharger. I wish you good luck.
Old 01-12-2010, 07:19 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Sounds like a timing belt issue to me. Just because the timing belt is intact doesn't mean it didnt slip time. How tight is it? It should be tight as a drum.
When was the TB done and by whom?
2000 New Beetle GLS TDI
Old 01-12-2010, 08:09 PM
Jonesboro Ar, USA
Car: 1999 Tdi
The belt is probually old the car has over 250,000 miles on it. Before i waste any body's time.....today i decided to find out what was wrong! This is wot i found. A small amount of starting fluid the car runs just. From there i found fuel filter not full? from there i pulled vacum from tank. Well it turns out after i took the fuel start stop solenoid out the pump car starts right up rev it twice shuts down take out stop start agian all is well.....i have me thinks a bad stop start valve solenoid. its letting go and shutting everything down. Problem is dont know where to order one from besides the stealer ship any ideas? AND YES I ALREADY HAVE A CAM BELT KIT ready to go as soon as i get the solenoid fixed.
Died on the Road Coloradobug 1.9 Liter TDI 51 02-01-2010 06:22 PM
HELP!!! car died.... bluebubble 2.0 Liter Gas 6 02-04-2007 03:48 AM
The day Blu-Ray died... iScott Miscellaneous Hoo-Ha Archive 40 01-19-2007 03:15 PM
died on me madison04 1.8 Liter Turbo 6 10-07-2006 09:31 PM
AC and fan died gabluebug 2.0 Liter Gas 9 07-06-2006 03:15 AM
