Quick check, belt wear issue - NewBeetle.org Forums
Old 04-13-2010, 09:28 PM
TDI_bubble's Avatar
Default Quick check, belt wear issue
I'm in need of someone to pop the hood real quick and tell me a couple things.
The AC drier, is it in a vertical position? Mine seems to be slanted and is now rubbing the serpentine belt.
How close is the power steering hose to the AC fan? Mine is touching 0.o I will be fixing/replacing a lot of the AC parts in the next week, everything is in the mail!
It seems the new to me bug was a little curb happy, it doesn't seem like the sheet metal is bent, and the rest of it is plastic that I see no cracks. Any ideas?
Old 04-13-2010, 10:39 PM
TDI_bubble's Avatar
Well it seems the passenger side engine mount is not bolted down!
Anyone else have an issue with this? It looks like one of the bolts broke, while the other looks to be tight.
There was some clunking going on with accel/decel but I figured it was from the worn lower rear A arm bushing(also on order).
Old 04-14-2010, 02:03 AM
doublebarrel's Avatar
Irving, TX, USA
Car: 2000 gls tdi
Sounds like someone reused the one time use torque to yield bolts.If one is broke it might be best to replace the other motor mount bolts.If a timing belt was done on it they may have reused bolts instead of replacing them.
Old 04-14-2010, 02:29 PM
TDI_bubble's Avatar
Damn I bet that's what happened then, the rear one is sheered off but the front is still there. Is there some sheet metal being bent when the engine moves front to back? It seems like its still bolted to the chassis with the front bolt.
Anyone have a pic of the passenger side frame rail with the engine out?
Check timing belt? elfwithagun 1.8 Liter Turbo 3 10-19-2009 02:14 PM
How do you check the timing belt robpad 1.8 Liter Turbo 1 09-01-2007 06:59 AM
Would you wear this? who_me285 Miscellaneous Hoo-Ha Archive 15 04-20-2007 10:47 PM
Alarm Issue and Inside Light Issue-HELP! tinarie01 Questions, Issues, Concerns, or Problems with the New Beetle 4 01-02-2007 06:36 AM
I had Timing belt and Water Pump changed now the Check Engine light fatdaddy Questions, Issues, Concerns, or Problems with the New Beetle 15 02-13-2006 02:27 AM
