Skid Plate, Cooling Fans, & CV Joints Best Pricing - NewBeetle.org Forums
Old 06-28-2010, 02:38 AM
Default Skid Plate, Cooling Fans, & CV Joints Best Pricing
Looking for Skid Plate, Replacement Cooling Fan assembly, Headlight Housings, & CV Joints - Best Pricing/source?
Suspect that we will be having a Mastercard meltdown soon.
Also any source for the oil spec for a 2006 New Beetle TDI? Dealer is only source in Tampa, FL and it's $8 bucks a quart!
Thanks.
Caaey and Jodi
Old 06-28-2010, 03:34 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Thanks.
Caaey and Jodi
Skid plate: VW TDI timing belts, aluminum VW skid plates, VW short shift kits, VW G60 clutch, and Race Pipes by www.dieselgeek.com
cooling fan: www.idparts.com
headlight housings: ebay (aftermarket) "VW Parts" - "Volkswagen Parts" - Parts and Accessories Catalog. (OEM)
CV joints: Depends. Is a boot just torn or is it clicking/worn out? If the boot is just torn, get a boot kit from www.idparts.com
If the joint is actually bad (which I doubt would be the case with a 2006 unless it has run with a bad boot for many years) your best bet would be a junkyard. Aftermarket axles are junk. OEM axles are $$$...$700 each I think?
Motor oil: If it were my car, I would just run Mobil 1 TDT 5w-40 or the Mobil 1 ESP 5w-40 Formula M (MB spec). Both of these are excellent oils that are proving to be superior to any of the 505.01 VW spec oils. If you insist on 505.01 only, go with one of the 5w-40 flavors available at www.idparts.com as the 5w-30 oils just are not capable of providing adequate wear protection to the cam and lifters.
Since you own a TDI, come on over to Fred's: Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community
2000 New Beetle GLS TDI
Cooling Fans Won't Run & No A/C markm7918 2.0 Liter Gas 5 06-25-2010 02:11 PM
Need skid plate help!! AmyJane Questions, Issues, Concerns, or Problems with the New Beetle 35 04-15-2009 10:09 AM
Skid Plate vibelife 1.8 Liter Turbo 2 12-30-2007 07:46 AM
Skid plate (cover plate) mbandalan Market Place Archives 7 07-28-2007 08:31 AM
Skid Plate!!!! Help!!! bla bla Technical Modifications 8 02-12-2006 03:15 AM
