Hi everyone. Found out there's another Beetle owner in one of my classes. His car is an 02 VW TDI auto. His door dinger stays on, all of the trans indicators (which gear it's in) stay on regardless of gear. He said he's got an intermittent CEL, but the car runs the same with or without it. He had an autoparts store scan it, and they told him it was a switch for the trans. (speed switch) I know I'm not the most versed with VWs, but I know on my Acura, if the speed switch is bad, my speedo quits. I know his main thing is trying to get the dinger to quit. He's got an hour drive each way to school.
Any ideas? Thanks. |
Door ding is due to the door lock sensor not knowing when the door is open or closed. Common issue. Does he have a hard time locking the car? That would be an issue as well
The speed switch is another common issue for the auto trans. Make sure that he takes care of that auto trans. How many miles? Should have the fluid and filter changed every 40k. Otherwise, he's looking at a swap in his near future (trust me...I just did one a month ago for the same reason!). The speed switch may cause issues with his speedo, as well as shifting in his trans eventually. I would have that replaced asap. Find a TDI guru in your local area. There is a sticky here as to who to talk to. They will do much better work and be far less expensive than any dealer. TRUST ME! You live and learn....I'm trying to help other TDI'ers learn prior to having to live it! Trusted Shops and Mechanics in TN European Service Works 5221 Pleasant View Rd Memphis, TN 38134 (901) 372-7050 www.innerauto.com http://forums.tdiclub.com/showpost.p...0&postcount=19 MF Automotive 5611 Washington Pike Knoxville Tn. 37918 www.mfauto.com (865) 523-7676 German Performance Options 1227 Lebanon Pike Nashville, Tn (615)248-9466 gpotuning@gmail.com http://forums.tdiclub.com/member.php?u=83007 http://forums.tdiclub.com/showpost.p...&postcount=617 Try talking to them first!
Just because it's done at a Dealer, doesn't mean it's done Right!!! "Probie" 2k12 ToD Checklist Dub Gestapo |
Thanks Michelle. I'll refer him to MF. They have a good rep (and great commercials) in the area. He says that driving and shifting is fine, but time will tell I guess.
I looked at it after class today. Other than the dinger, I notice that on the dash (where it tells what gear you're in) shows that you're in all gears. They're are all blacked. I've got a buddy with a Vag Com, and I'm gonna try to get the two together. Thanks again Michelle. Oh, and the car's knocking on 125K. |
Okay. Got this critter scanned with a Vag Com today. He's throwing a P0705 in OBDII and the trans came up saying the multi function switch was in an unknown state. From what I can tell, the PO705 is a trans switch. Any thoughts? Thanks for the tips Michelle, I'll pass it along to Michael(the guy that has the TDI) BTW, do the manuals hold up better with the diesels? I've kicked around the thought of a TDI at some point.
Thanks. |
yes, manuals are much better for the diesels. Not only do the manuals hold up but the mpg is MUCH better. 38-40 for the auto 44-48 or more for the 5 spd!
As far as I know the trans switch is a pretty common issue with the autos. Hopefully someone here will chime in as to how to fix it. |
| 99 NB gls 2.0 auto - Issues = p* codes (very long, Intro + much info) | Tomuza | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 02-16-2010 11:45 AM |
| NEW 00 Auto. TDI w/ 140000 | WATKNS | New Member Forum | 8 | 02-26-2009 02:33 PM |
| Auto TDI vs Gas Manual | sideshowbob | New Member Forum | 9 | 08-17-2007 12:04 AM |
| WTB: TDI Auto Beetle | WS6HUMMER | Market Place Archives | 2 | 06-17-2006 02:27 AM |
| 1998 NB TDI Issues | Nerd | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 04-05-2006 07:27 AM |
