Does it smell like diesel fumes? Can you be more specific on the smell?
wires burning somewhere? I know electrical burning smell gives me a headache. Check your fuses and wires. on top of the battery box too. But you will have to be more specific on the smell...can't imagine what it could be....
Just because it's done at a Dealer, doesn't mean it's done Right!!! "Probie" 2k12 ToD Checklist Dub Gestapo |
Pick up a battery powered Carbon Monoxide (CO) tester at your local hardware store and place in your vehicle while driving. High carbon monoxide levels will cause headaches. Also have your exhaust system inspected for leaks.
Rich |
Does it smell like diesel smoke? Might be a good idea to have the exhaust checked out for leaks. They are easy to spot under the car, just look for the soot stain. A common place for them to leak would be on the downpipe flex joint, the cat. converter weld, or the coupler. Another thing to check would be the EGR cooler flex pipes.
The last thing would be to make sure that the firewall is sealed off as it is supposed to be. Experiment with the airflow controls to see if it gets any better, depending on where the smell is coming from, you may/may not want the recirc. function on.
Thanks for replying. I took the car to an exhaust expert. He seems to think it may be coming from around the turbo. He was not totally sure, so he adviced me to take it to the voklswagen and have them give it a look over.
The smell seems like burned oil. I cleaned the carpet and seats hoping that would help but very little. I don't believe it is electrical. I'm familar with that type of smell. My children have always teased me cause I have a hound dog nose. I can smell everything. One thing I have noticed it the decreased mileage. Maybe a airleak or gas leak? Comments are O so appreciated. Ps I am a Er nurse. At least I will be close to some oxygen or intubation equipment if I need it...hahaha Just kidding, Tres |
Stay away from the VW dealer, they'll probably try to sell you a new turbo that you don't need.
Go here: MF Automotive 5611 Washington Pike Knoxville Tn. 37918 MF AUTOMOTIVE - Knoxville Tennessee's Independant VW and Audi Specialist (865) 523-7676 |
It's possible your turbo could be consuming oil (ie failing) and you're smelling it, that would go with reduced mileage... I've seen that happen on plenty of AHU TDIs.
My bets are on an exhaust or EGR leak. |
Hi guys thanks again for your help. I took my car today, to a great diesel place in downtown Chattanooga, TN.(Southeast Diesel) They gave the car a complete look over and tried to help me as best as possible. Wouldn't even take in money for trying to fix this problem. They are great guys!
We have came to the conclusion, the guy that owned it prior to me worked at a chemical plant. Southeastern thinks maybe the old owner had some type of chemical on his clothes or shoes and got it in the cab. I feel like an idiot! I would have never thought od that. Tomorrow I will totally clean the carpet and seats from one end to the other. I will post more in a few days after seeing if this works. Thanks again. |
Imagine what it smells like to those of us following you in traffic! I hate Diesels for that reason! They ALL stink..I don't care what year they are.
- Joe ![]() 2001 Techno Blue Pearl 5 spd GLS. Heated leather, fog lights, power sunroof, alloy wheels. |
Besides, this person was having a serious problem and found out it wasn't even because of the exhuast fumes or anything else NB related, previous owner at a chemical plant...wow, who would have thought it. Tres Bug, I hope you get that problem taken care of, hate to have to see a good beetle go to waste because of a former abusive parent (NB owner). Good Luck ![]()
2006 Sunflower Yellow Beetle TDI Bumble Bee aka Bumble Newest addition to our family 1998 Black Beetle 2.0 Rupert Last edited by BumbleBeeTDI; 09-24-2010 at 05:02 PM.. Reason: Changed Name |
Biodiesel has no ill smells and causes no allergic reactions. And even with a straight pipe, a TDI smells less than a vehicle with a 3 to 6 inch exhaust -- most Trucks and smaller heavy duty equipment. Comments like these irk me as if we followed Europe's lead and had a 60%+/- fleet of diesels we'd use less than half the current consumption of fuel, resolving MOST of our economic and sustainability issues. Instead, however, we're the nation that likes to demand more complex and inferior and inefficient hybrid gas-electric vehicles, using diesel power to ship tons of raw materials around to refine into batteries and destory other lands that aren't our own (after all environmental protection is only within the scope of our borders, right? -- that's sarcasm...), and gloat about our new and uncomfortable vehicle that gets a staggering 42 to 44mpg real world. I have a twisted frame, blow a tire or two tires every oil change from premature wear, and I STILL get 43 in the city. In my bug. With it's little turbo diesel. Hybrids impress me not. But, no offense, mindsets like yours are why they are popular and prominent. Food for thought. (also it's been studied, ULEV emissions un-restricted are still far more deadly than unrestricted diesel emissions... so while diesel makes your head hurt and is visible it has less nanoparticles to cause damage. Gasoline exhaust is mostly nanoparticles, you can't see or smell them, and it will kill you quickly.) |
I have done a lot of research today and found out there are more than just me out there with this problem. There is a compound called cosmoline which vw company coats the floor pad with to protect the car from rust. There are a lot of people out there withthis problem. They have told me to remove the old carpet pad. The smell and headaches will go away. This is the same stuff rifles and hand guns get coated with to protect from rust.
Believe it or not, but there are actually people out there who like their car smelling like crayons. Yuck. I will remove the carpet and see if that relieves the problem. |
Ah, so that's what that smell is. I always wondered what caused it.
You know any interior shop should be able to make you a new floor mat... but I'd suggest stripping the carpet out entirely and rhinolining it. I have seriously considered doing this to my bug many, many times. I may be taking a trip to Memphis, I don't know where Pikeville is but I'd be happy to come and help you take the interior apart. It's NOT as bad as you think, less than 20 fasteners and the whole carpet comes right on out. We've even machine washed one or two before... YouTube - BJ's carpet wash |
| Uh-oh my beetle is causing problems! | BeetleLinz1125 | The New Beetle Experience | 3 | 04-06-2010 05:30 AM |
| remote key headaches | fxn351@aol.com | 2.0 Liter Gas | 0 | 10-15-2009 12:10 AM |
| i dont know what is causing this to happen. looking for advice. | akaPRINCE | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 07-04-2008 09:07 PM |
| Causing riots with the kids... | BarefootHoodoo | The New Beetle Experience | 22 | 10-14-2006 04:26 AM |
| What's causing this code? | Oyveychris | 1.8 Liter Turbo | 13 | 03-06-2006 02:29 AM |
