2000 New Beetle TDi - Relay Intermittently Buzzes when Turning Ignition Key - NewBeetle.org Forums
Old 10-26-2010, 03:44 PM
Default 2000 New Beetle TDi - Relay Intermittently Buzzes when Turning Ignition Key
My 2000 Beetle TDI is intermittently having a problem starting. Sometimes when you turn the key over the #53 Relay Switch for the Clutch Pedal Switch is buzzes. I am also able to start the vehicle without depressing the clutch pedal. Has anyone experienced this issue? I have searched the forum with no success. Please help with any insight.
Thanks,
Andrew
Old 10-26-2010, 04:26 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
If the car starts without the pushing the clutch, then the relay is fine. Sounds like the clutch switch is not operating correctly. There are 2 switches on the clutch pedal, the one you want to replace is white/gray and is WAY up on top of the pedal assembly.
2000 New Beetle GLS TDI
Old 10-26-2010, 04:53 PM
Yeah, I just figured out that the plunger for the white/gray clutch switch isn't fully retracting. However, I'm still having the starting issue with a new switch.
I have swapped the #53 relays around, but no solution. I guess I can rule out the relay.
98 beetle will not turn every attempt , but will start after the 5th time turning key fss13foxtrot 2.0 Liter Gas 4 01-04-2010 02:08 PM
1999 beetle key stuck in ignition copperflower Questions, Issues, Concerns, or Problems with the New Beetle 4 09-18-2008 01:32 AM
ignition switch relay ? C89ZX7R Questions, Issues, Concerns, or Problems with the New Beetle 1 12-29-2005 05:58 AM
lost of spare ignition key and backup key faulty(no data found)...PLS help atomwhiz Questions, Issues, Concerns, or Problems with the New Beetle 1 12-11-2005 11:36 AM
lost of spare ignition key and master key faulty with no data found..help pls! atomwhiz Technical Modifications 1 12-11-2005 11:11 AM
