temp gauge - NewBeetle.org Forums
Old 10-29-2010, 11:26 PM
deltona, FL, USA
Car: 99 beetle tdi
Default temp gauge
how and where would you tap into to install a water temp gauge?
Old 10-30-2010, 12:43 AM
Evanrude's Avatar
~Feel the Sting~
Longview, WA, USA
Two ways to do it that I know of.
The first way is easier, but could potentially be the worst way to go.
It requires cutting your upper radiator hose and inserting an adapter in the new cut that allows for the connection of a temperature sensor to be installed.
You can get a CNC machined version from 42 Draft Desgins, here...
VW Universal Water Temp Adaptor
The second way provides a much less destructive way of achieving your end results. (BUT, I'm not sure if it'll work for you as you have a 1.9 tdi, I thin the water hoses / connectors are the same, but you'd wand to verify that before buying this part). You purchase a CNC machined piece that fits between the coolant flange and the head. The major thing here is, it bolts directly into the head, so it's sturdier, and less likely to leak or break down.
The downside is, unless you are mechanically inclined, you'll probably need to get this one done by a mechanic due to the location of the connection on the engine head. I purchased this particular piece before I realized that I can't reach the end myself. Now I have to save up and have a mechanic do it for me! And, if you go this route, you may consider putting in a new thermostat since it's at the exact same location.
VW mk4 1.8T Water Temp Adaptor
Old 10-30-2010, 12:50 AM
deltona, FL, USA
Car: 99 beetle tdi
thanks both are awsome
Old 10-30-2010, 12:59 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Get the universal one. That 1.8T flange adapter will not fit a TDI.
2000 New Beetle GLS TDI
Old 10-30-2010, 02:22 AM
I use the universal one from 42DD. There's actually a plastic straight coupler with a plug on it on the left hand (drivers) side of the bay. Maybe for coolant flushes? Anyway I just replaced that with the universal temp adapter. If you're on a budget and feeling brave you could try tapping that plastic fitting. I would have done it but I didn't even notice that it existed until I had everything in hand on install day.
Knowing what your water temp really is is great though. You'll be very surprised how long it takes TDI's to warm up.
Old 10-30-2010, 09:22 AM
Evanrude's Avatar
~Feel the Sting~
Longview, WA, USA
OH!!!!
Forget what I said previously ... I forgot to give you one other link!
I'm buying one of these soon I hope.
UltraGauge Automotive Information Center and OBDII Scan Tool
only $60 and it scans / clears codes, and gives you something like 34+ gauges for your car =)
The thing can read up to 74 different things from your car but it's dependent upon your ecu and car. So the Beetles usually give you around 34 or so.
Water temp being one of them
See this other thread for photos of it in use and more info on it
Ultra-Gauge.com
And, this only takes 2 seconds to install, and you can use it in multiple vehicles! *heh*
Old 10-30-2010, 01:20 PM
pm22071985's Avatar
USA
i agree with evanrude about using the obd to monitor water temp....
i had a vdo water gauge in my jetta and have compared it to the readngs obtained with my scangauge, its very accurate.
Outside Temp Gauge The NEW Ringo Questions, Issues, Concerns, or Problems with the New Beetle 5 08-19-2010 01:35 PM
Use Oil temp gauge for Water temp? Beltaine Technical Modifications 10 02-09-2009 02:21 PM
Temp Gauge Coastie617 1.8 Liter Turbo 5 04-19-2007 02:49 AM
