2001 beetle heat problems - NewBeetle.org Forums
Old 11-06-2010, 09:10 PM
Default 2001 beetle heat problems
I just recently purchased a 2001 beetle and the heater is not blowing hot air. Does anyone have any suggestions on what I need to do to fix my problem?
Old 11-06-2010, 10:01 PM
HudsonValleyVDub's Avatar
Hudson Valley Area, NY, USA
Car: Techno Blue 01 GLS 5 spd
So you let it warm up, and turn it all the way to hot and with the blower on...you get NO heat at all?....or is it maybe blowing through the wrong vents? If none at all, the first thing I'd look at would be the coolant level. If ok, try asking in this thread:
Ask the Mechanic for free!
Good luck.
- Joe
Old 11-06-2010, 11:36 PM
akasha1963's Avatar
Kaylee Bug
Nashville, TN, USA
Car: 2001 Silver Arrow GLS 2.0
Having you tried switching it front the front vents to defrost? If it blows out the defroster but not the front then it could be a vacuum line/switch issue.
Old 11-08-2010, 06:44 PM
Knoxville, TN,
TDI engines take a while to warm up, but at some point you should be getting warm air from the vents.
Few things I can think of that might be a problem....
Water pump - if the water pump is not pumping, then you will get low heat output and even better, an engine that overheats. The issue with a Beetle is that there is no temp gauge.
Blend door - the blend door is what controls how muck air flow goes though the heater core in the dash. The less air that flows though the heater core, the less hot air you will get. The blend door is adjusted by the temp knob for the VHAC system on the dash. When you turn the temp knob, does it feel like it is moving freely? There should be some resistance to it. The knob turns a gear, which in turn moves a lever arm, which in turn pulls/pushes a cable, which in turn moves a lever arm connected to the blend door. So as you might guess, there are a few places where failure can occur.
Heater core - if the heater core is clogged up for some reason, then coolant will not flow though it and thus, no hot coolant to warm the air. I've never seen a clogged heater core on a Beetle.... Passats on the other hand...
Hope this helps out.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 11-08-2010, 10:18 PM
doublebarrel's Avatar
Irving, TX, USA
Car: 2000 gls tdi
Could also be your thermostat.Mine wasn't closing all the way so engine would not get up to normal operating temperature.
Two Heat problems at Once mikarmagsp 1.9 Liter TDI 2 11-13-2009 02:05 PM
2001 New Beetle Problems randalll1990 Questions, Issues, Concerns, or Problems with the New Beetle 8 08-05-2009 03:22 PM
no heat inside my 2002 2.0 Beetle inkman27 2.0 Liter Gas 2 05-08-2009 05:58 PM
Problems with 2001 Beetle neisei New Member Forum 1 05-20-2006 03:42 AM
speedo problems with 2001 sport beetle sledmeister 1.8 Liter Turbo 5 11-21-2005 04:09 PM
