First Winter with TDI - NewBeetle.org Forums
Old 11-27-2010, 10:38 AM
Mtsodave's Avatar
Dave
Westerville, OH, USA
Car: 2006 TDI Harvest Moon
Default First Winter with TDI
This will be my first winter with my TDI, and I would like to know at what temperature I might need to worry about a fuel additive. I live in Central Ohio, which is generally temperate, but we can see below zero degF temps on occasion. Nothing forecast below the 20s so far.
My TDI is a 2006.
Thanks.
Dave
2006 Beetle TDI 5-speed
Old 11-28-2010, 10:51 PM
Lew's Avatar
LewRegistered Member Lew is offline
SE, GA, USA
Car: 2005 Beetle GLS TDI 5 Speed
I use Power Service from Wal Mart. Cost 6.97 for the 24oz Bottle. I add 8 oz every other fill up.....Get the white bottle which is for extreme cold weather. The Silver Bottle is for warmer areas. It's a good thing!
Central Florida TDI Club
Wife's 2005 manual with RC1+ Rocketchip just sipping Beetle Juice 47.5 MPG Avg on Fuelly.com. Ross Tech Vag Com!
Old 11-28-2010, 11:05 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
If you use fuel from stations with high turnover (i.e. lots of truck traffic) you will likely be fine as the suppliers generally do pretty well with providing winterized fuel. Sudden cold snaps early or late in the season can be a problem however. That said, it is always a good idea to use an additive. Not only for protection against gelling, but also for lubricity and to help deal with any water that may be in your fuel supply.
Stanadyne is a good year-round option. I typically use Power Service (white bottle) in the winter and Power Service Diesel Kleen (silver bottle) the rest of the year. I'm not sure why Lew states that he only does this every other fill-up...thats not really effective.
If you are going to use additive, use it at every fill-up. Follow the directions on the bottle, no need to be exact on the measurement. Just splash some in and eyeball it. A little extra won't hurt anything.
2000 New Beetle GLS TDI
Old 11-28-2010, 11:39 PM
NewBeetleMechanic's Avatar
Real life Beetle mechanic
In the old days we used to use heat tape on the lines and heated tank blankets on the fuel tanks.
Winter storms! GINA Miscellaneous Hoo-Ha Archive 14 02-26-2007 02:42 AM
Winter yet or what?!? 05NavaBug Miscellaneous Hoo-Ha Archive 71 12-10-2006 09:31 PM
Nasty Winter LadybugEwa The Canada Corner 8 03-27-2006 01:05 AM
Is 38mpg average for 2005 NB TDI-PD in winter? slpopp 1.9 Liter TDI 9 03-16-2006 11:55 PM
Winter TDI imsos04 1.9 Liter TDI 27 02-26-2006 11:45 PM
