I would think gelled fuel, not ice. Did you try any additives? I always use them since the beginning of winter until spring and never had a single problem with diesel gelling up on me. Extreme cold weather also weakens batteries.
x2! Once a battery has enough bad cells, as long as you still have it connected, it will draw so much of the power that you are jumpering into the car, that the engine won't crank, you'll be lucky if you even get a click out of the solenoid. Hello... It had been telling you it was going bad!
Do you wait on cold mornings till the glow plug light goes off? Do you notice a difference if you wait for it to turn off or not? You may have a glow plug issue. I agree with the battery but make sure you are letting the glow plugs work before trying to start.
You might have a starter going bad on you.Mine got to where it wasn't turning the engine over fast enough to start.The colder it got the slower it would crank.I took the starter to the parts place and they tested it and said it was good.I bought a new one anyway and it cured my starting problems.
i had the same problem with my car. Altough mine is a 98 which is alil different than your 01, you may want to replace your glow plug relay first. that did it on my car. just a thought.
98 TDI Bug. First car. Tune, Gauges, Exhaust, Nozzles.
I replaced the battery in my '99 GLS last weekend. It was an old battery (at least 4 years old since the last charge), long before I purchased it last year. I added gasoline antifreeze (you probably know about that better than I do). Definitely get the battery checked and/or replace it, it's a simpler and somewhat cheaper solution (or at least by process of elimination). When my NB "died", the battery light didn't come on. We couldn't jump start it at all. I waited a few days and tried again, and finally the light come on.
Question: VW doesn't make block heaters for bugs (right?) but is it possible to have a battery warmer? |
I bet its just a dying battery. Diesels take a lot of juice to get cranked with the glow plugs, and with it being so cold lately its super important that the battery is good. If its weak at all, you're going to have real problems starting.
Thanks all for the helpful replies. I'm of course praying that a new battery will take care of the problem. Planning to purchase a Duralast H6-DLG, $156.99 at AutoZone tomorrow. Even if it isn't the entire issue I need a strong battery to see me through the winter. I do wait for the glow plug cycle and I've even tried consecutive cycles as suggested on tdiclub.com. My main concern is that the car successfully started and abrubtly died about 3 minutes later during a smooth idle. It's never done anything like that before. And what about the excessive smoke at startup? Could I have a timing issue?
I would strongly advise taking it to a competent TDI mechanic for a thorough inspection, and possibly a TB re-do among any other necessary repairs. This is likely the primary cause of your issues, but there may be other factors at work. A weak battery or starter (or even just dirty/corroded connections) could be causing the slow cranking. The stalling after it started could be fuel gelling. Try some Power Service Diesel 911 (red bottle) and see what happens. I'm not sure how well the fuel stations down there treat their fuel for cold temps like you've been having. Running some Power Service (white bottle) with every tank would be a good idea in the winter months. Come on over to the forums at Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community - lots to learn there.
I'd guess its the fuel, they might not sell winter mix there. Like he just said powerservice in the red bottle should ungel it and the white bottle should keep new fuel flowing. They might not sell either of those around you either because it doesn't normally get cold. Getting the car into a warm garage or shop could also help ungel it
Any group 48 battery will do, Walmart has them for around $70. The Deka 48AGM(over $150) is the best, but you shouldn't need it in a warm area. Last edited by macdave; 01-15-2011 at 09:18 AM.. |
I just installed an Optima 34R Red top in my NB. It is just a little tall which makes closing the battery box properly an issue. However it is strong and turns the engine easily. I have rolled it over atleast 50 times with no start. Temp is now 38 and climbing. I'm wondering what to do next? I still suspect gelling and/or other fuel delivery issue. I have a replacement filter but thought changing it just to push gelled fuel into it might be futile? Should I be able to hear a fuel pump whine? How might I check to see if I'm getting fuel up to the filter? engine?
BTW, I appreciate all the help. I know newbies can be a pain. Anyone recommend a competent TDI guru near Selmer, Tn? TDIclub says: European Service Works 5221 Pleasant View Rd Memphis, TN 38134 (901) 372-7050 |
You said you changed your fuel filter. Did you fill the new filter with diesel. If not you have air in the lines. Get the air out and fresh diesel to the injectors and it will crank.
Central Florida TDI Club Wife's 2005 manual with RC1+ Rocketchip just sipping Beetle Juice 47.5 MPG Avg on Fuelly.com. Ross Tech Vag Com! |
As macdave said, there is no pump in the tank of your car, the injection pump handles all of that. To see if you're getting fuel, crack loose one of the injector line nuts, only about a 1/2 turn or so and then crank the engine and see if fuel squirts out. If it does, the engine is getting fuel and you have other problems. If it doesn't, then you gelled up. When re-tightening the injector line, don't go caveman on it. If you over-tighten, the ferrule on the line will be damaged and cause it to leak. If you get fuel, you have a couple other checks to make: - Check to make sure the anti-shudder valve is open and not sticking shut. - There are other possible causes, see here for more info and troubleshooting info: Car won't start troubleshooting - TDIClub Forums If you don't get fuel: - When turning the key to the ON position, does your glow plug light turn on? It should always at least flash for a second. If not, then you have a bad relay 109. They are known to flake out and will cause a no-start condition as it supplies power to the ECU. - Change the fuel filter. If it did gel up, the filter gets plugged with wax that dropped out of suspension. Treat the fuel in the tank with Power Service Diesel 911, it should be available at most any parts store. Last edited by DZLBUG; 01-16-2011 at 04:22 PM.. |
| Help My oil filter is frozen in place and wont budge! | kodihi | 2.0 Liter Gas | 9 | 12-22-2010 09:28 PM |
| 05 Hard to start...now...won't start | 05tdi | 1.9 Liter TDI | 19 | 11-19-2010 07:01 PM |
| Radio frozen after flat battery jump start | p48ker | Car Audio | 7 | 08-22-2010 12:31 AM |
| Odometer Frozen | marshallcole | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 05-10-2008 12:30 AM |
