P2108 Code - NewBeetle.org Forums
Old 02-08-2011, 10:44 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Default P2108 Code
Did a search; turned up nothing.
Anybody know what a P2108 code is? Car seems to be running OK; it's an 06 TDI Beetle.
'02 & '05 Acura RSX
Dodge Cummins, Ford Ranger
M151 Ford
Old 02-08-2011, 10:51 PM
SixChuter's Avatar
Bixby, OK, USA
Car: 2008 3W/2004 TS
Bentley says:
Throttle Actuator Control Module Performance (Motor For Intake Flap V157 Malfunction)
If you don't know where you're going....any road will take you there. G. Harrison
Lily's Pics
Gandalf's Pics
My Profile Album
Old 02-09-2011, 12:38 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Thanks. My Bentley doesn't list it.
I'm wondering if this is related to cold weather.
It may be time to buy VAGCOM. Any suggestions as to which VAG-COM?
Old 02-09-2011, 12:51 AM
SixChuter's Avatar
Bixby, OK, USA
Since I was only going to use mine on NBs I just bought the basic VCDS license and HEX-USB+CAN interface. They do offer pro versions if you want to expand the types of vehicles you can scan. Ross-Tech has a great site. They make it easy to figure out what you need. Good luck. I have a lot to learn about what I can do with the Vag-Com but it has already been a great help.
Old 02-10-2011, 01:45 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
What will the HEX-USB+CAN model do that the KII-USB won't?
Old 02-10-2011, 02:41 PM
BumbleBeeTDI's Avatar
Dad of Bumble & Rupert
Greenup, KY, USA
Car: 2006 Beetle TDI & 1998 Beetle 2.sl0w 5 speed
This tells you the difference between all three kits available
Ross-Tech: VCDS: Interfaces
2006 Sunflower Yellow Beetle TDI
Bumble Bee aka Bumble
Newest addition to our family
1998 Black Beetle 2.0
Rupert
Old 02-10-2011, 11:06 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Is the Beetle part of the "Mark V Golf" technology? Because I don't see Beetles listed in the Ross-Tech compatibility chart.
Old 02-10-2011, 11:30 PM
Ross-Tech: VAG-COM: New Beetle / Cabrio Applications
Old 02-10-2011, 11:52 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
HEX+CAN is for newer VW's, all NB's are still essentially MKIV's. On your car, it won't do anything more than a KII USB cable.
2000 New Beetle GLS TDI
Old 02-11-2011, 01:01 AM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Good. That saves a hundred bucks.
p-code? pepino68 1.8 Liter Turbo 6 10-03-2010 12:18 AM
turbo intake code abe, engine code aeg huck731 2.0 Liter Gas 8 11-03-2009 11:43 PM
Code help!! skittle Questions, Issues, Concerns, or Problems with the New Beetle 3 06-16-2006 03:57 AM
ABS Code ??? jazzman_q 2.0 Liter Gas 1 05-31-2006 04:43 PM
cel code 411 racer12306 2.0 Liter Gas 5 01-03-2006 03:53 PM
