MAP Sensor on 2000 W Beetle? - NewBeetle.org Forums
Old 02-17-2011, 09:23 PM
Question MAP Sensor on 2000 W Beetle?
THe Beetle is throwing code P1155 which is for the MAP Sensor. Problem is I can not figure out where the darn sensor is located. Any help would be great!! Thanks
Old 02-17-2011, 11:44 PM
my98tdi's Avatar
Mo-Town, WV,
Car: 98 TDI
the map sensor is usually on top the intercooler. check there. hope that helps.
98 TDI Bug. First car. Tune, Gauges, Exhaust, Nozzles.
Old 02-18-2011, 01:47 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Get VCDS on it and do some logs, generic P codes are worthless for this. These sensors don't fail very often, you probably have some other boost control issue; bad actuator, vacuum line, sticky VNT.
IF, and thats a BIG if, its the MAP sensor...its on top of the intercooler. I can't remember if you can get at it by taking off the fender liner or not. If not, then the front bumper and fenders have to come off.
But like I said, get VCDS on it to see what the problem actually is.
2000 New Beetle GLS TDI
o2 sensor replacement on 2000 1.8 Turbo .. DOBERDEWD 1.8 Liter Turbo 3 08-21-2010 03:59 AM
MAF SENSOR 2.0 Beetle giink 2.0 Liter Gas 6 03-08-2010 05:55 PM
Camshaft sensor location on 99 beetle 2.0L DonM77 2.0 Liter Gas 6 03-03-2009 07:46 PM
