I am in the Dallas TX area and this morning my engine dropped. I found the ear of the block where the front motor mount bolts up is broken. I am looking for eigher someone who can drop engine and repair block or repalce with good used engine. I'll pay cash for the right mechanic.
You Sir are a lifesaver. Thank you o wise one. ![]() ![]() |
I gotta be honest i just got a tdi beetle and am learning. I ran across that thing about 3 days ago to a week and thought hmmmm i wonder really why you would need this. Otherwise i would have been zero help.
i HAD NO IDEA THIS WAS AS MUCH OF A PROBLEM AS IT IS WITH VW. Thanks again for the help
Sent from my DROID2
well teh VW dealership in Killeen TX did the timing belt about 85k miles and 7yrs ago so i guess i can forgive them. I wil be installing blue locktight on the new bolts however.
Wow, I had never seen or heard of this happening before either, but glad to see there is a very reasonable fix out there for it.
BlueLghtning - Follow me on my Spot Messenger 2000 Silver Beetle TDI w/5spd 2001 Blurple Beetle TDI w/5spd BlueLghtning & GypsyAngel's Pics <-- Click |
I have that repair on mine,last owner had timing belt done by somebody that reused bolts and even put one in that wasn't the correct one.My son borrowed my bug and the engine dropped on him.Glad I had an aluminum skid plate on,it keep the engine from dropping far enough to hurt anything.I had a heck of a time getting the broken bolts out.I replaced them with the proper bolts and did the repair from dieslegeek.Had a trusted TDI guru do the timing belt about a month after that and haven't had any other problems.Contact Marin at marinmm2001@yahoo.com if you need a good VW mechanic or go to www.TDICLUB.com to find a TDI mechanic.
| Replace Engine Block No Start | JSSEC | 2.0 Liter Gas | 1 | 06-07-2009 12:36 AM |
| Broken Motor Mount AGAIN | Papa Gino | 2.0 Liter Gas | 2 | 04-26-2009 11:11 PM |
| Bahh broke off a damn bolt in the engine block. | savethebluths.org | 2.0 Liter Gas | 6 | 10-28-2008 10:10 PM |
| coolant leak at engine block | Babycar | 2.0 Liter Gas | 0 | 06-28-2008 05:06 PM |
| Timing Belt Replacement-Engine Mount? | fasteddy51 | 1.8 Liter Turbo | 2 | 06-02-2006 08:35 PM |
