Would this be a good candidate to convert to manual? - NewBeetle.org Forums
Old 04-06-2011, 05:42 PM
OhSnap's Avatar
Time to unpimp ze auto!
Orland'oh, Floriduh, USA
Car: 2002 Snap Orange 1.8 CC
Default Would this be a good candidate to convert to manual?
2002 Volkswagen Beetle Yellow 83k 2 owner
I'm still searching for the bug of my dreams! What do you guys think? Yes, it's autotragic (well it apparently hasn't crapped out yet) but should I consider buying this one? Other than the auto, everything else is what I wanted.
Old 04-06-2011, 06:09 PM
Make sure the timing belt has been done already at that mileage.
Old 04-06-2011, 09:00 PM
marvins_dad's Avatar
I BELIEVE!
Dallas, TX, USA
Car: 2002 DIYCGCC TDI
Hey - it does have Hello Kitty Stickers
Looks like you have a dent in the middle of the passenger's side rocker. Both of the door cards will need to be reupholstered (sagging).
Definitely ask about the timing belt.
I have a 2002 TDI Autotragic and at 103k still have a transmission. My suggestion is to save up for a manual, but don't pull the trigger until you have to...why spend $2500-3500 right off the bat, use some cash to do some cosmetic repairs and possibly the timing belt first.
marvins_dad ~ antoine
Old 04-07-2011, 03:46 AM
OhSnap's Avatar
The problem is now that gas prices have risen, it's so hard to find a manual TDI bug! I've been saving for a TDI bug since last year, and kept having setbacks. I have 8000 to spend, but what I want is scarce. My dream bug:
TDI
manual
sunroof
light-colored leather (I live in FL, black is hell on bare skin)
yellow, orange or bright blue in color (yes color matters and no I don't want to repaint)
Old 04-07-2011, 05:35 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
Definitely REPLACE the timing belt RIGHT AWAY.
I have a 2002 TDI Autotragic and at 103k still have a transmission. My suggestion is to save up for a manual, but don't pull the trigger until you have to...why spend $2500-3500 right off the bat, use some cash to DO THE TIMING BELT FIRST.
FTFY
No matter what car you buy, save yourself some time and lots of money by doing a full TB job right away. Do not trust anything a seller tells you. Budget for the TB replacement right away.
Sent from my DROID2
2000 New Beetle GLS TDI
Old 04-13-2011, 02:49 PM
Columbia, NJ, USA
Car: 98 A4 NB Silver
When doing this swap, unless you are doing it yourself and have a donor car available, it will run you in the neighborhood of 4k. A rebuilt 01m is generally 2500 + installation.
If you have your heart set on doing this swap keep looking at CL etc. for donor cars.
Get the full t-belt kit with w-pump, rollers etc.
I recommend Bora Parts, ID parts or Dieselgeek.
Old 06-06-2011, 02:13 PM
TX, USA
Car: 2002 New Beetle TDI
I personally think the 5 speed swap can be done for less than $2k. I found my 5 speed on Car-part.com. When I went to buy it, I told them what I was doing and they sold me everything needed at a package price. You'll probably do extras like upgrade clutch, solid flywheel instead of DM, new axles instead of used, new rear main seal, etc. Then again, I did all the labor myself. All and all, the wiring was the most challenging but not bad.
2002 Cyber Green Slug Bug TDI SOLD
1996 Passat Wagon TDI (daily driver)
2011 Honda Accord (wifes car of course)
Election '08.... New candidate shakes up election scarabY2k Miscellaneous Hoo-Ha 18 10-13-2008 12:36 AM
How do i convert X to X? FineExampl Miscellaneous Hoo-Ha 7 01-07-2008 06:27 PM
Convert to HID I got a problem about the DRL W@NDER Technical Modifications 1 07-31-2007 03:54 AM
Convert. top question(S)..help! bugbabe New Beetle Detailing/Cleaning 4 10-21-2006 02:21 AM
Wheels on Convert titanic New Beetle Convertible 19 05-10-2006 03:11 AM
