Injector Pump Rebuild - NewBeetle.org Forums
Old 06-14-2011, 01:14 AM
Wyldeman's Avatar
TX,
Car: 98 DTI
Default Injector Pump Rebuild
Need an injector pump rebuilt....any body out there that can do it reasonable?
what about hans on the net?
Please let me know asap going to get it off tomorrow...98 TDI standard 130k
THX
Wyldeman
Old 06-14-2011, 01:20 AM
DO NOT send it to Hans Diesel, a.k.a Prothe. His pumps are junk, as are his rebuilds.
Not sure about TDI pumps, as I'm more in the older IDI diesel scene, but I'm sure someone can let you know.
Is the pump leaking? From where? Might be an easy seal to change and not need an actual rebuild.
Old 06-14-2011, 03:29 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
THX
Wyldeman
DFIS in Portland is the only place to send it. Make sure you have the correct lockdown tools to get the timing belt back in place right. If the belt will need changing anytime soon, this would be a good time to replace it along with the water pump, tensioner, 3 rollers and new stretch bolts.
Sent from my DROID2
2000 New Beetle GLS TDI
Old 06-14-2011, 03:34 AM
DZLBUG's Avatar
I Am Breitbart
BTW, what are the symptoms that make you think it needs rebuilding?
Sent from my DROID2
Old 06-14-2011, 10:27 AM
Wyldeman's Avatar
TX,
Car: 98 DTI
Default rebuild
well its making a bad lil knocking noise and last time i had it out it had been losing power.....had the codes come up on it after several reads on and the way it acts id why i feel its the pump.
It would lose power before it started knocking trying to go up a hill it just got a lil worse in time. like i said last time i took it out about three months ago...I left and was doing as usual then it lost about all power turned around and came home opened the hood and the pump was clattering loud and didnt want to idle right. It sounded like it was running on two cylinders,,...
It sounded louder than this YouTube vid YouTube - &#x202a;Tdi engine noise&#x202c;&rlm;
It had been giving me problems way before this as i had just pick it up from a friend.....seemed like it didnt want to climb a small hill. Lost power going up. on flat ground no problem but i drive 60 to 65 any how. It was throwing a code which i cant remember now....seems it had something to do with the limp mode....
Thx to all!!
Old 06-14-2011, 02:56 PM
How many miles on the car? Is the timing correct?
Old 06-14-2011, 03:42 PM
Wyldeman's Avatar
TX,
Car: 98 DTI
Default timing right
yes the timing is right.....i did a belt change at 100k as you can see in my first post it has 130k on it now....
Old 06-14-2011, 05:29 PM
BillyMagnum's Avatar
TDI Owner
LaVale, MD, USA
Car: 2000 NB TDI Red Flamin'
dieselgeek sells a resealing gasket kit...as for internal rebuild not sure. Listen to dzlbug if it is the pump send it to portland. Don't go with prothe. I actually had already ordered from my pump from prothe when I started posting here on the forums. no problems and its been in for almost 10k now. But it's not worth the risk from him, way too many people have problems with his pumps. Hopefully I'm just one of the lucky ones. knock on wood. Just my 2cents.
David
BTW: don't know if any of these links could be of some help. They all pertain to my IP problems...not glow plugs like two say, but if you need GP help its there too, I just had a few bad things at once haha...anyways here ya go
Changed Glow Plugs and now Won't Start:(
Fuel Pouring Out at Start:(
VWVortex.com - NB-Fuel Pouring Out at Start
VWVortex.com - Changed glow plugs-now won't start?
Anybody rebuild an automatic? MOREPOWER Transmission Talk 1 04-10-2011 04:57 AM
HELP!! How much for a 1.8L head rebuild VA bugn 1.8 Liter Turbo 7 04-07-2011 12:45 AM
Suspension rebuild Bo185 Technical Modifications 13 04-29-2010 03:18 AM
Needed a secondary air injector fuel pump for a 1998 gas vw beetle. snoopy041824 New Beetle Classifieds 2 05-31-2009 11:34 PM
secondary injector pump leaking osprey 1.8 Liter Turbo 4 05-15-2007 02:06 AM
