2000 TDI tried to start, now won't turn over - NewBeetle.org Forums
Old 06-23-2011, 01:06 PM
Default 2000 TDI tried to start, now won't turn over
Hi guys, just want out to start up the car this morning for my trek to work. Rained a bunch last night (probably insignificant).
Anyways, went to start her up, cranked hard for a second (normal), then nothing. No odd noises.
Now when you try to start, nothing. No cranking. Usual dash lights are on.
I am going to check the timing belt (God I hope not) and misc fuses. Thinking its the fuel pump?
Old 06-23-2011, 01:21 PM
Checked a few things
- Timing belt seems fine.
- Oil level fine
- Fuses (although truthfully I am not sure which ones I should be checking) all appear fine.
Any reliable way to test the starter?
Old 06-23-2011, 05:00 PM
Do you hear a click at all when you try to start it? Battery good?
Old 06-23-2011, 09:07 PM
No click, nothing. Battery seems fine, all headlights, signals, fan going at full speed.
I finally got the bugger out, bench tested it. Grounded starter to battery, hooked possitive up to large possitive in on starter... Ran a smaller wire from same possitive on battery to smaller possitive terminal on starter.. nothing but a small spark.
Old 06-23-2011, 11:02 PM
A few questions...
What's the mileage?
Anything unusual prior to the no start?
Cup, my beetle suffered the same thing- she jumped timing and bent valves. She's a 1.8t, but there's an orger, MichelleRoze who owns a TDI and suffered the same thing you're going through. Her issue was pretty much like mine.
I really, really hope that your beetle isn't going through the same thing- i wouldn't wish that on my worst enemy.
Please keep us posted on what's up.
Old 06-23-2011, 11:29 PM
New starter, runs like a champ..
Old 06-23-2011, 11:44 PM
Awesome news! That made my day
2000 Beetle Suddenly Won't Start new_beetle_lover 2.0 Liter Gas 5 09-25-2010 08:05 PM
98 beetle will not turn every attempt , but will start after the 5th time turning key fss13foxtrot 2.0 Liter Gas 4 01-04-2010 02:08 PM
My NB won't start on the first turn of the key liquid_cocaine Questions, Issues, Concerns, or Problems with the New Beetle 6 01-03-2010 05:33 PM
Hard to start 2000 Beetle mss542 Questions, Issues, Concerns, or Problems with the New Beetle 3 10-18-2008 11:49 AM
2000 beetle won't start/doesn't turn over... sunshine219 2.0 Liter Gas 7 06-22-2008 12:32 AM
