Radiator fan may be draining battery - NewBeetle.org Forums
Old 06-30-2011, 01:40 AM
Default Radiator fan may be draining battery
I've had my 2002 Diesel Beetle for four years and this is the first time it's ever done this. I went out to my car and the battery was dead (not unusual, except that I got a new battery over a year ago and it hadn't done it since). When we tried to jump it off, a fan in the engine started as soon as the batteries were connected....25 minutes later and no headway on actually starting the car. So we switched to jumping it off with a truck...still no luck.
What do I need to do? My best guess is coolant problems making the radiator fan not shut off, but I couldn't get the cap off to check and the sensor hasn't been going off anyways.
Is there anything I can do to fix it at home? How much will it cost to be fixed? Also, I'm 19 with no knowledge of cars, so over-explaining is appreciated!
Thanks.
Old 06-30-2011, 02:28 AM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
I think I would start with having the charging system checked; this can be done for free at most auto parts stores like autozone or o'rielly's, if you can get the battery charged and driven there... they can check everything out with a diagnostics computer, while the car is running. This will confirm that the alternator (component that charges the battery) is good and that the battery is good as well. That would eliminate the charging system as a possible problem and they could scan the car for any trouble codes too.... a beginning in the process of figuring out what is wrong.
Aftermarket Head Unit draining battery? marvins_dad Car Audio 12 08-06-2011 01:04 AM
2000 Beetle Stereo Draining Battery? Corey Car Audio 0 03-09-2009 10:43 PM
transmission draining my battery? luminousNB Transmission Talk 3 10-08-2008 07:45 PM
Battery Draining Overnight arnard Questions, Issues, Concerns, or Problems with the New Beetle 9 05-10-2007 01:51 AM
wtb - radiator fans + fuse block on battery GLUVBUG Market Place Archives 2 07-10-2006 10:20 PM
