8/99 NB Cluster Lights - NewBeetle.org Forums
Old 07-11-2011, 07:21 PM
Stafford, VA,
Car: 96 b4v glx/tdi conversion
Default 8/99 NB Cluster Lights
When the headlight switch is turned to "on", all cluster lights illuminate briefly (1 second or less) then shut off darkening the cluster completely. It's as if a relay is sensing a short and interrupting current flow. It is not the headlight switch. Might there be such a circuit breaker on the cluster itself ? Any insight ? Thanks.
Tail Lights not working after replacing Brake Lights megepo0 Questions, Issues, Concerns, or Problems with the New Beetle 3 05-21-2011 12:04 PM
Interior Lights/Clock/Licene Plate Lights kellar91 Questions, Issues, Concerns, or Problems with the New Beetle 2 04-24-2011 04:42 PM
ALL cluster lights Tesla 2.0 Liter Gas 8 08-22-2008 08:03 PM
Help with instrument cluster indicator lights Greta Questions, Issues, Concerns, or Problems with the New Beetle 3 04-27-2007 04:11 AM
Missing warning tones & cluster lights? nroakley Questions, Issues, Concerns, or Problems with the New Beetle 7 07-25-2006 03:43 PM
