Need help with steering angle sensor - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 01-13-2012, 05:43 AM
abelsolis07's Avatar
Big Spring , TX, USA
Car: 2005 GLS 1.9 TDI 5 speed
I replaced the turn signal switch. The ticking stopped. I'm jumping for joy.!!! Still haven't pulled the codes. I saw the steering angle sensor when I pulled the steering wheel off. looks like a simple replacement job, but I think that it needs to be programmed after installation. thinking about bypassing the seatbelt sensor with a resistor. I fnally made some progress. Awesome.
  #22 (permalink)
Old 01-14-2012, 01:12 PM
Lew's Avatar
LewRegistered Member Lew is offline
SE, GA, USA
Car: 2005 Beetle GLS TDI 5 Speed
First things first. Let's make sure you know what the codes are. Take your car by Autozone and let them run a scan. It's no charge! Write down the codes and post them. Autozone will not clear codes, however you can if you ask the man to let you do it.....Once you clear the code, scan again and see if it comes back....Stealerships will tell you anything. Don't trust them!
Category:Fault Codes - Ross-Tech Wiki
http://wiki.ross-tech.com/wiki/index.php/00591
Central Florida TDI Club
Wife's 2005 manual with RC1+ Rocketchip just sipping Beetle Juice 47.5 MPG Avg on Fuelly.com. Ross Tech Vag Com!
  #23 (permalink)
Old 01-18-2012, 03:18 AM
Hi Lew, thanks for your help
I called o'Reiley's and asked if they could run a scan and pull the codes for me and they said " No, we leave that to the professionals". I went to Autozone and they ran a scan and no codes came up. I kind of figured that would be the case, I've had issues with this autozone before. But, I figured that I'd tackle the seatbelt latch first. I took a good look at it and found that the four wires going into the latch are broken ( I'll try to attach a pic ). I see that you own an 05 GLS TDI like mine, awesome car isn't it? Do you know where I can get a reasonably priced replacement seat belt latch?
  #24 (permalink)
Old 01-19-2012, 03:06 AM
I ordered a new seat belt latch from the stealership in Lubbock today. I got it for $96.00 shipped. sounds like a pretty decent deal. It should be here in a couple of days. I also found an awesome DIY thread on removing the seat. Feel like I'm one step closer to solving these anoying electrical problems. Once I get this one knocked out, I can start looking into trying to fix the steering angle sensor problem.
  #25 (permalink)
Old 01-20-2012, 12:34 AM
It's not a bad job. I got a whole clock spring from eBay for under $100 shipped, dropped it in and reset the codes. It's fine to this day.
This isn't a really common problem, it's not really a wear and tear item. Make sure the part numbers match that's really important. Call the dealer, give them your VIN and get the part number for the clock spring your car needs and shop for that specific PN.
  #26 (permalink)
Old 01-20-2012, 12:38 AM
It's kind of funny you replaced that latch. All you're fixing is the idiot light in the cluster but if it's worth $96 to you then all the power to ya!
I wonder what the 3rd wire is for. Both of my NB's use 2 wires for the belt latches.
  #27 (permalink)
Old 01-22-2012, 04:11 AM
The latch I replaced actually had 4 wires. You can see the yellow wire sticking out under the green wire in the pic.It broke off inside the latch. seems like I read somewhere that two wires are for the seatbelt alarm/idiot light and two are for the airbag system. I changed outthe latch today. Not too difficult but I had to buy another 12 point triple square bit. I found a set of four at O'reillys
for $4.99. The airbag light is still on though. I guess I will have to get it cleared.
Wide angle inside rear view mirror Mike Hunt Parts and Accessories 3 03-25-2009 02:00 AM
can the high beam's angle be changed? killerw 1.8 Liter Turbo 2 05-23-2007 02:08 PM
Split angle mirrors for NB? tequilaiam Styling Modifications 6 11-30-2006 03:20 PM
September '06 Photo Assignment: Unusual Angle jdesigns Photography 50 10-02-2006 06:19 PM
FS: Euro wide angle (split) mirror glass tjd Market Place Archives 4 05-14-2006 04:37 PM
