Rear Coil Spring inside Dimension - NewBeetle.org Forums
Old 01-07-2012, 05:56 AM
Default Rear Coil Spring inside Dimension
I am wondering if anyone has a set of rear Coil springs sitting around from a New beetle that could messure the inside dimension of the base of the springs. I am looking for the inside size were the spring sits on the spring pad. I believe it is about 2" but want to make sure.
Thanks in advance.
Old 01-07-2012, 05:54 PM
TDI_bubble's Avatar
There is dimensions for the metalnerd type lift kit for diy.
I have pdf's but cant post a pic without uploading somewhere.
bottom of spacer needs to be 2.25", top needs to be 2.13" where it goes inside the spring.
Old 01-07-2012, 06:11 PM
Thanks
Inside rear window needs glue? Shipper New Beetle Convertible 2 08-15-2010 06:30 PM
Stock Coil Spring Feeler BUGSTUFF Parts and Accessories 0 04-27-2009 06:01 AM
Rear spring install????? Photo Technical Modifications 1 06-11-2006 05:27 AM
