Sluggish or no start in 2002 Beetle TDI - NewBeetle.org Forums
Old 11-19-2012, 02:30 AM
Albemarle, NC, USA
Car: 2002 Beetle 1.9 TDi
Default Sluggish or no start in 2002 Beetle TDI
I have read these forums now for about 3 hrs with no luck. Ok I have a 2002 Beetle TDI 1.9. Yesterday I couldn't get it started it was 42 degrees F outside. Jump started and started fine. Today I had to go rescue the wife because it wouldn't start. Whe I got there I had read that disconnecting the engine coolant sensor would trick it into starting, and that worked, when I got her home I removed the old sensor and put in a new one, still having the problem. I metered the glow plugs same voltage as the battery, and with the coolant sensor disconnected I have voltage on all 4 connectors for the wires supplying the plugs, but nothing when the sensor is hooked up. Battery is really weak, and after charging when I bypass the sensor, the plugs will kill the battery, could all this be caused by a weak battery, will the plugs not turn on with a weak battery? Email responses to flametamer123@yahoo.com
Old 11-19-2012, 03:14 AM
I bet it is a bad battery. Diesels take a lot of juice to get started, especially once it gets colder out.
Sent from my SCH-I405 using AutoGuide.Com Free App
Old 11-19-2012, 11:55 PM
Albemarle, NC, USA
Default I'm Thinking Good Thoughts LOL
I put the new battery in today, started fine all day, we will see in the morning when cooler. Thanks for your help, keep your fingers crossed.
2002 turbo will not start Ericl 1.8 Liter Turbo 12 10-31-2012 04:14 PM
Help, My 2002 beetle wont start bigmicro Questions, Issues, Concerns, or Problems with the New Beetle 5 01-11-2012 12:52 PM
2002 Turbo new beetle ran out of gas, now won't start. Bumblebeebug 2.0 Liter Gas 2 09-01-2010 08:49 PM
2002 TDI won't start Ashbug1818 1.9 Liter TDI 11 06-30-2010 04:26 PM
2002 Beetle Turbo won't start irenejai 1.8 Liter Turbo 9 04-05-2010 11:53 AM
