2001 vw tdi - NewBeetle.org Forums
Old 11-29-2012, 03:56 AM
Default 2001 vw tdi
Hello
Problem with the TDI. Pulled up to have tires rotated, mechanic could not start car. Engine cranks, but will not start. All lites are working properly. Relay 109 is working properly. The fuel shutoff is not getting 12 volt. I suspect this is the problem, no 12 volt, valve cannot open to give fuel to the injectors. VW indicated relay 109 sends power to another device, which I would assume would send that 12 volt to the injection pump. I have been looking on-line for wiring diagrams for this car, but no luck. Strange---car is running just fine. Shut it off and it will not start. Problem is no fuel, but need to find out why the fuel shutoff solenoid is not getting power. I even bypassed that by disconnecting the wire on the solenoid, then applied 12 volt directly to the solenoid. Still no start. Cracked fuel lines and cranked engine--still no fuel.
Anybody else had this happen?
Thanks
Scott
Old 11-29-2012, 11:09 AM
Front Runner's Avatar
RTP, NC, USA
Car: 2013 VW GTI - 4 Door
If you dont get a response here, I would try the tdi forum because I'm sure you'll find info there.
Bill
2013 VW 2.0L 4 Door GTI
2012 2.0L Turbo Beetle "DYSTURBD" - Unexpectedly sold
1999 1.9L TDI New Beetle "V-Dub" - Sold at 180K
Old 11-30-2012, 02:48 AM
Knoxville, TN,
Just for giggles, make sure the choke valve isn't stuck shut. Remove the rubber hose from the intake and see if the [NOT A THROTTLE BODY BUTTERFLY VALVE] is in a closed position. It should be open to allow air flow to pass through.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 11-30-2012, 02:55 AM
boertje's Avatar
Coeur d'Alene, ID, ID,
Car: 01 GLS TDI
You mean the anti shutter valve that is part of the EGR valve.
2 2001 bugs TDI GLS with 6 speed ERF manual trans, 2000 golf and 2002 Jetta 6 speeds with TDIs, 2006 bug TDI GLS with DSG, 2003 bug TDI GL with 6 speed, 2002 bug TDI GLS with 5 speed.
looking to buy 2001 TDI please help rimwalker 1.9 Liter TDI 4 06-07-2012 08:20 AM
WTB:2001 1.8T, what to look for??? BumbleBeeTDI 1.8 Liter Turbo 4 01-05-2011 11:49 AM
2001 NB Using Oil akersanth 2.0 Liter Gas 5 10-28-2009 11:42 PM
Fs: 2001 2.0 Gls Vayleen Market Place Archives 2 05-10-2006 04:49 AM
