I have a 2001 VW Beetle TDI. Everytime I drive over 80 kmh the turbo cuts out. It will reset if I shut the car off and turn it back on. Then with any speed over 80 it cuts out again. Any opinions or suggestions would be appreciated!!!
Jeff |
Your car is going into "limp mode" probably from too much turbo pressure. The mechanism that controls the pressure gets stuck on TDIs if you dont drive hard very often. Its actually better to get on the gas at least one time every time you drive it to exercise the turbo.
Pepe! Wrecked, goodbye my loyal friend Black 1999 TDI 53.75 MPG best ![]() My 1970 Bus "Benny" See Pictures and Mods to Pepe! Click here for places to get parts for your Beetle |
The car is bone stock. I have had the car for 6 months now and have just realized that this car has had a clogged "one way valve" from the turbo that has not allowed the turbo to function properly. I just had the valve replaced and it is a new car, as you can imagine!!! Now the turbo kicks out and I did have a warning light to the effect of "too much turbo"...
I'll try to explain better!
When I had the valve replaced...it was a new car as the turbo started working. The problem with the turbo dying did not begin until after the valve was replaced. So, when I first got the car...the turbo did not work because the valve was plugged. Then after the valve was replaced...the car worked great! Now, it kicks out only after a few minutes of driving... |
From what side is that photo of the TDI turbo taken, and what's the best way to get to the turbo and lube the actuator? Just to help newbies on turbo preventive maintenance. I've only sprayed some metal protectant from below.
Bean juice on the tank! What is biodiesel? www.biodiesel.org, http://www.eere.energy.gov/afdc/altfuel/biodiesel.html Where can I get some? http://forums.biodieselnow.com/ |
That photo was taken from the top, if you were to look behind the engine with the intake off. I couldnt see when I did it but I just soaked the top of the turbo with PB Blaster and aimed for the pivot point were the lever goes inside where the arrow is pointing.
| Rep problem | Lnzbug | Suggestion Box | 20 | 04-20-2006 10:13 AM |
| Big Problem! | BlackBug | 2.0 Liter Gas | 4 | 02-15-2006 06:25 PM |
| What could be the problem? | CyberGrnBug01 | 1.8 Liter Turbo | 2 | 02-08-2006 10:09 AM |
| Turbo leaking problem | Naen | 1.8 Liter Turbo | 11 | 10-14-2005 06:38 PM |
| Problem! Need some help. | kg4fku | 2.0 Liter Gas | 9 | 10-10-2005 12:19 PM |
