The New Beetles don't have a temperature gauge so when you first start it, you will see a blue thermometer until the engine warms up. You're supposed to be gentle with it until the light goes off. I remember the first new beetle I had...My first thought when I started it after I bought it was "oh great, I've had it for 12 hours and I already broke it!!!
Just as d_merry said, don't worry about the blue light. Your fine unless your light turns red. All that info is in your manual...
Cori
My wife did the same on her beetle, it was alright till the Blue light was flashing just after we got it. It appeared that the stealership, did not check the coolant level which was down alittle bit causing the blue light to flash, if this happens check the fluid level and add to the line. Use the correct coolant!
But the blue light solid is normal if it goes out after the engine is warm.
My car "Gus" Gray 2002 NB GSL TDI has everything even leather and sunroof MY wifes car "Daisy" a Yellow 2001 NB GSL TDI everything but leather and sunroof.best mpg 53 and 805 miles in one tank Truck Black Ford F350 Powerstroke Diesel (of course),CC,dully, 350hp+ running on WVO! |
| Blue coolant light comes on? | ChuckDubDub | 1.9 Liter TDI | 22 | 05-17-2012 03:16 AM |
| Where's the coolant sensor on a TDI? | Shamrockez | 1.9 Liter TDI | 4 | 09-25-2007 07:09 AM |
| Blue coolant light flashing? | DruzeTito | 1.8 Liter Turbo | 7 | 04-19-2006 12:12 AM |
| Engine coolant light blinks!! | jetskiboy88 | 1.8 Liter Turbo | 5 | 11-11-2005 05:15 PM |
| TDI coolant and transmission fluid what works best? | Neil O'Malley | 1.9 Liter TDI | 9 | 09-28-2005 06:11 AM |
