2002 GLS 2.0L engine codes AVH & AZG - NewBeetle.org Forums
Old 06-29-2006, 11:46 PM
Mundelein, IL,
Car: 2002 GLS 2.0
Default 2002 GLS 2.0L engine codes AVH & AZG
Hello,
My engine code sticker in the trunk says, AVH yet the sticker on the timing belt cover says, AZG. I know both of these codes are drive by wire throttle controlled cars, but any ideas why the different codes on the same car? Anybody else have this?
Thanks,
Old 01-22-2011, 07:11 AM
Spicewood, TX, USA
Car: 2002 gls herbie
i'd like to know too
http://www.facebook.com/tilithrim
Add me (mention the org)
Old 01-22-2011, 02:09 PM
Supercharged98's Avatar
Fountain Inn, SC, USA
Car: 98 NB S/C'd 2.0L 5 sp
Wow, you dug up a old post. Do you have the same situation? If VW is like other manufactures, the car was scheduled to get a AVH (2001 & up) engine and the body was labeled to get one. Most likely, by the time it reached the area in the assembly line that puts in the engine, they ran out of the AVH and had to use a AZG (2002 & up).
For an example......I have a 1989 Dodge(one of the last ones built for 89)and they ran out of 89 V-8 318CI, and had to use a 1990 V-8. It has a complete different ignition. So, when I have to get a cap and rotor for a tune-up, I have to get ones for a 1990.
"Deutsche Stahl"
lightbulb & Superman's 2002 Luna Green GLS lightbulb Photos: New Beetles 70 03-16-2012 01:40 AM
Quick question on Samco TIP and engine codes Anaconda 1.8 Liter Turbo 3 08-27-2006 04:18 PM
Wacky blinkers & AirBag light? 2002 GLS digitalputty Questions, Issues, Concerns, or Problems with the New Beetle 2 06-30-2006 08:14 PM
Couple Of Engine Codes, Plz Help!! Zookie Questions, Issues, Concerns, or Problems with the New Beetle 8 11-30-2005 07:00 PM
Engine codes Skoobahead Questions, Issues, Concerns, or Problems with the New Beetle 5 11-16-2005 02:42 PM
