Dip stick tube - NewBeetle.org Forums
Old 07-01-2006, 01:07 AM
Lezliej's Avatar
Lezlie
MO, USA
Car: 2000 2,0 Vapor Blue, Neuspeed Supercharger, sweet stock otherwise
Exclamation Dip stick tube
Gosh, what was VW thinking making that cheap plastic dip stick tube using plastic that gets brittle and breaks? Anyway, I replaced mine today but a little bit of the old plastic tube chipped off and fell into the oil tube. I will change the oil before I start it again but should it be OK? Will the plastic just come out with the old oil?
Thanks, Lezlie
Old 07-01-2006, 01:22 AM
Mr B's Avatar
Merrimack, NH, USA
Car: 2000 GLS Yellow
I'd put it up on ramps, to tilt it back a little. If it doesn't come out with the oil, rinse the pan with diesel fuel. This will also clean out the sludge in the bottom of the pan. If your afraid to pour it through the motor, use a small hose and a funnel, and put it in through the dip stick tube.
When all else fails, blame others.
Old 07-01-2006, 01:43 AM
Lezliej's Avatar
Lezlie
MO, USA
Thanks so much!
Lezlie
dipstick tube gator Technical Modifications 19 02-01-2010 05:42 PM
Oil dipstick tube Bug Dog 1.8 Liter Turbo 2 05-29-2006 05:54 PM
WTB 2.0 dip stick houseing peice fatdaddy Market Place Archives 4 02-12-2006 02:59 PM
You, You...... Dip Stick riyank Questions, Issues, Concerns, or Problems with the New Beetle 5 12-09-2005 11:22 PM
ABD Racing Turbo Big Bore Intake Tube for Golf/Jetta/Beetle (01 and up) StealthTurbo Market Place Archives 5 12-01-2005 01:45 AM
