Drawing LOTS of power while shut off - NewBeetle.org Forums
Old 07-09-2006, 11:46 PM
Geckoho's Avatar
Default Drawing LOTS of power while shut off
The wife's '99 is doing the following:
-Battery is dropping from a solid 13.5v to 10.2v overnight.
(changed battery before I really got into troubleshooting the problem)
-Checked for any lights or accessories left on. None found.
-Voltage from alternator while running is 14.1v. (no problem there)
-Unhooked the ground at the battery and checked for draw with everything off. It's drawing 12.5 Pulled all fuses one at a time and that number wouldn't drop.
-The only thing I was able to narrow down(at least I hope)is that many of the engine fuses (little picture of an engine and electric bolt and the (!) fuses) show a 12.5 draw even when everything is off.
Any clues, ideas, or more trouble shooting checks?
Old 07-10-2006, 10:55 AM
Duffy's Avatar
Duffy II
Jonesboro, AR, USA
Car: 2009 NBC Harvest Moon
Default Dead Battery ..
Sounds like your old battery is just dieing. To check for current draw, you will need to insert a current meter in series with one of the battery leads. You will see a very small current draw in the milliamp range (sorry, but I don't know what is normal). When a battery reads 10.2 volts, yeah its dead! Does the voltage on the battery rise (appx 14V when running? That would indicate a good alternator - quick check.
Tom
Old 07-11-2006, 01:47 AM
73standard's Avatar
Jacksonville, FL, USA
Car: '99 NB/ '73 Standard
Could also be a bare wire somewhere.
Old 07-20-2006, 01:33 AM
Geckoho's Avatar
Problem occurs with new battery as well as the old one.
I'm still at a loss as to where this parasitic power loss is coming from. I'm wondering if it's ECM or a relay. Maybe a timer that's not shutting down? I know some vehicles keep some systems energized up to 20min after shutdown.
Old 08-01-2006, 03:22 PM
KS,
Car: 1999 Beetle / 1990 Corrado G60 / 1979 Scirocco
Geckoho,
You might try the security circuit. Does the battery voltage drop if the car remains unlocked overnight? Had something like you describe happen to me, but not everyday or all the time. Turned out to be the truck release motor that opens the trunk when you use the keyless entry. Just a thought
AC will not shut off. MrMeatCleaver 2.0 Liter Gas 2 07-09-2006 06:04 PM
something running after car shut off CYBERGREENCC 1.8 Liter Turbo 9 07-03-2006 10:56 PM
Lots Of Lights! Ugh!!! AmyWalker Questions, Issues, Concerns, or Problems with the New Beetle 5 03-13-2006 06:51 PM
So, my driver's door is perpetually shut! kcfoxie Questions, Issues, Concerns, or Problems with the New Beetle 4 12-18-2005 05:12 PM
Lock pops out when the side door is shut... Flopka2 Questions, Issues, Concerns, or Problems with the New Beetle 2 10-10-2005 06:21 AM
