I need to replace the entire headlampunits in my 98 NB. What "gotcha's" am I going to run into if I try to do it myself?
Are there any previous threads regarding headlight removal and replacement, maybe with sterp by step directions? Thanks in advance. |
I believe there's a how-to on replacing the head lamp bulbs here somewhere. Although it may not sound relevant, it is. To replace the bulbs, you need to take out the whole light assembly.
The biggest problem will probably be the driver side, as the battery is blocking access to the clip holding the assembly in place. Unless you have very large hands (read: Hulk), you should be able to work around this, as removing the battery probably takes longer than figuring out how to get in there without removing the battery. Overall, it should be an easy enough task. Locate the how-to in the technical section, look it over and you should be ready to go.
1998 Red New Beetle 2.0 Automatic |
| 01 Bug Headlamp HELLLLLLP!!! ! | raceinsider | 1.8 Liter Turbo | 5 | 07-22-2006 03:41 PM |
| NB Headlamp replacement | Bob K | 2.0 Liter Gas | 3 | 07-20-2006 10:59 PM |
| Headlamp rubber seal said goodbye | AZBug | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 03-07-2006 05:28 PM |
| Replacing my headlamp story... ;-) | Jerry7171 | Miscellaneous Hoo-Ha Archive | 7 | 12-11-2005 01:41 AM |
| FS: HID for New Beetle - incl Headlamp assembly | ksanchez | Market Place Archives | 8 | 11-02-2005 08:47 PM |
