Need a Timing Belt in the Tri-State or New England area? - NewBeetle.org Forums
Old 08-15-2006, 03:49 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
Default Need a Timing Belt in the Tri-State or New England area?
As you all know, the timing belt is a key part of your engine. VW reccomends replacement at anywhere between 60-105k depending on year and motor. If the service is not done on time, the belt could jump time or snap, both causing expensive repairs. While it is not a cheap repair to do this key maintenance, it is vital to your car's well-being to do this in a timely fashion. I reccomend that when doing or having someone do this repair, one purchases the "Ultimate" timing belt kit from ecstuning.com. This includes a new timing belt, water pump, tensioner, serpentine belt, and stretch bolts. For the 2.0 motor, I personally reccomend a replacement interval of no more than 80k in between changes. This seems to be the safest maximum mileage you can stretch out replacement.
I am available to do this repair at a reduced cost over the dealer, and can do this repair at your convenience. I can travel to you if you have ample space to work, or alternatively, you can come to me. I have air tools and access to the proper tools to set tension.
My labor rate if you come to me is $200 for the 2.0 motor. If I travel, I factor in a rate of $.15 per mile in addition to the above prices. This covers fuel for my car, shop supplies that I will need to purchase, and any emergency supplies I may need (rags in a box, oil for my air tools, wear/tear on my 1990 Cabriolet, etc.). My rates are fair, and my work comes backed with a warranty that I personally will uphold in writing. I have many personal references that I can provide to you upon request. I am also a certified Volkswagen technician as well.
This is a day job, and while I work speedily, I do not rush this job as it is a key part in your car's lifeline. I prefer to start as early as possible in the morning to maximize daylight hours because I work outside at my house.
I can be reached either thru the private messaging service here or through email at thecheat1206@gmail.com .
--Justin
Old 08-20-2006, 12:23 AM
The Cheat's Avatar
Bump...
I did angelworks' belt and pump yesterday.
I do travel...keep that in mind.
Old 08-22-2006, 04:22 PM
angelworks's Avatar
Write it like it's hot!
If I can make it there--NY baby, USA
Car: 98 Red 2.0 ,5 speed -70K
Yes he did!
And we got up bright and early and made the two + hour trip down to IKEA in MA and back the next day, Sat.
Not one hiccup and she even felt a bit more responsive.
*Oh and that ticking --- she needed oil J*
Do not hesitate to have Justin do this job for you, you won't be sorry. He is low key and takes his time while being very gentle with your baby.
Princess throughly enjoyed the whole experience!
Drive it like you mean it!
My Greenie Blog
Body in the United States/ Heart in Ireland ~~~ Princess Poppy 1998 5 spd Red
Old 08-22-2006, 04:31 PM
Lnzbug's Avatar
MINI & NB FOR LIFE!
Arlington Heights, IL, USA
Do you have a hotline for questions? We are waiting for the kit from metalmanparts.com and John will be doing the install. My car died and the belt isn't turning. I hope all goes well. Ellen
Old 05-18-2007, 01:16 AM
The Cheat's Avatar
this offer is still on the table! i'm free whenever, email or pm with questions. i do other work as well.
Need a Timing Belt in the Tri-State or New England area? The Cheat 1.9 Liter TDI 4 03-19-2008 04:25 PM
Timing belt change (Atlanta area): $200 Porkchop 2.0 Liter Gas 22 08-20-2006 10:09 PM
Need a Timing Belt in the Tri-State or New England area? The Cheat 1.8 Liter Turbo 4 08-17-2006 11:38 AM
Timing belt??? CyberGypsy 1.8 Liter Turbo 8 04-02-2006 03:45 PM
Timing belt kevin_k Questions, Issues, Concerns, or Problems with the New Beetle 6 03-07-2006 11:10 PM
