a good way to check for leaks is to get a spray bottle of soapy water and spray the hoses where you think they may be leaking. when you see bubbles you know you've got it nailed down.
not sure if you'll need pre-formed hoses or not (pre-formed are cast in a mold for specific bends) but i think the hoses you want are 3.5. yep just buy the correct diameter hose, remove the old and install the new. pliers help to get the old ones off sometimes. |
^ X2
use soap and bubbles will signal the bad guy
Bugs dont Leak! they are marking their territory!
223 Hp says the dino..but traffic says 15 mph DARN.... Can you get me one of those empty highways that appear on T.V. Car commercials? |
I vacuum leak is best detected with a spray of starting fluid at the joints of the hoses! Common sense tells you that soap will only get sucked in under vacuum, not produce bubbles!When you hit the leak with starting fluid the engine will speed up, and you can then shut the engine off, and inspect the hose! Good luck, Earl ![]()
75 year old car nut
Sound idea in theory, but starting fluid wil dry out hoses that may already need help anyway.
well your both wrong ! water= bad for moter
starte spry = bad for ruber why dont you use a propaine torch (not light) and just run it along the vac lines .. and for the vac lines ya can use any type as long its the same size !! and for a oil change well .. get 5L of 5-15 Pure synthetic and a good fram oil filter and change it your self !! anyhow what do i know .. just been fixing beetles for the last 15 years :P
fast and loud thats how i like it !!
I may try the water method and see if that works. Do you just pull the hoses off and put a new one back on? Sounds and looks easy, I just want to make sure I don't damage something in the process.
If I find the hose and get it fixed, can Autozone clear the code for me and if that is the problem will the CEL go away? Thanks for the help! |
If you computer geeks don't know enough about cars to find and repair a vacuum leak, and I even know how to spell "vacuum", you better find a stealership to lighten your wallets!If you have a bad hose causing a leak, the air leaks into the engine, not out! If the hose is bad, who gives a s**t if you get some starting fluid on it? Propane will have the same effect to raise the engine speed when the leak is located, Not"BOG"it. I've had, and worked on my own cars since 1954, and have always used starting fluid to locate vacuum leaks, and have never had an issue with "damaging a hose with it! I may be wrong, but you will have to show me some proof that those hoses can be damaged by starting fluid, or WD40, which will produce the same results in finding leaks! By the way 1idjack, if starting fluid won't make the engine react, then why does a small leak throw a code???? Good luck finding a stealership, Earl Last edited by blue'99; 09-09-2006 at 10:00 PM.. |
If you computer geeks don't know enough about cars to find and repair a vacuum leak, and I even know how to spell "vacuum", you better find a stealership to lighten your wallets!If you have a bad hose causing a leak, the air leaks into the engine, not out! If the hose is bad, who gives a s**t if you get dome starting fluid on it? Propane will have the same effect to raise the engine speed when the leak is located! I've had, and worked on my own cars since 1954, and have always used starting fluid to locate vacuum leaks, and have never had an issue with "damaging" a hose with it! I may be wrong, but you will have to show me some proof that those hoses can be damaged by starting fluid, or WD40, which will produce the same results in finding leaks! If you have success with the "soap method" where do you see the bubbles, at the tailpipe????? Good luck finding a stealership, Earl |
Help! I just replaced the vacuum hose, everything went perfect. However, I can still hear the hissing sound. The hose is new (i tried 2 hoses) and it's still hissing. It sounds like it's coming from the connector point of the hose, I think the to fuel regulator. I have clamped it hard and it's still hissing. Any ideas?? Help?!!!!
| What is the OEM breathing hose? | mezonesxbox | Technical Modifications | 8 | 06-03-2006 07:45 PM |
| Hose???????? | veedub71 | 1.8 Liter Turbo | 2 | 05-05-2006 04:27 PM |
| WTB: The Long Skinny AC Hose | K-BL | Market Place Archives | 1 | 02-22-2006 09:17 AM |
| missing secondary air hose | jazzcat | 2.0 Liter Gas | 2 | 11-16-2005 05:38 PM |
| Codes and the hose from the airbox | shuffs | 2.0 Liter Gas | 5 | 11-09-2005 02:37 PM |
