P0301 Cyl 1 Misfire..can I drive car? CEL on. - NewBeetle.org Forums
Old 10-02-2006, 01:08 AM
VA,
Car: 98 New Beetle
Default P0301 Cyl 1 Misfire..can I drive car? CEL on.
my first guess would be to remove/replace plug and wires. good idea or bad? i hear that access to the plugs is a pain, so is this something I should take to a shop? The car appears to be driving normally. i noticed a pending code for CYL1 some months ago and forgot about it. today the CEL came on. So, is it ok to drive until i can get new plugs and wires ordered? And how hard is it to replace them? I have dielectric grease at the ready!
Old 10-02-2006, 03:40 AM
[lot]'s Avatar
Montreal, Qc, Canada
Car: 99 Silver 2.0 GLS
It's not difficult to do it yourself.
You should change the plugs and the wires while you are at it. You can order the parts from 1stvwparts.com
If you want to know how to do it click here link
Old 10-09-2006, 12:51 PM
VA,
Car: 98 New Beetle
plugs and wires replaced 4 days ago..piece of cake -thanks! Got the CEL reset, was driving fine. Fast forward to last night: my daughter just called and said it is now sputtering, CEL flashing then steady. One thing, we have had a lot of rain. I don't have a VAG-CON but a pretty decent OBD-II computer which i will plug in when she limps on home.
Update: P0302 code cyl 2 misfire, P0301 code pending. previously, it was a p0301 set but the engine ran fine. when i pull cyl#2 plugwire from the running engine, i notice no difference (i.e. it appears cyl 2 getting no spark) and engine still runs the same (bad). Sound like a bad coil?
BTW, i checked resistance across the coil as suggested in manual. resistance was 5500ohms across cyls 3 and 2 and 5600 across 1 and 4. made me wonder if the coil is really bad since those values are in spec.
Old 10-09-2006, 08:22 PM
btb's Avatar
btbNewBeetle.org Member Sponsor btb is offline
Boston, Mass, USA
Car: MY00 2.0SC, MY99 TDI
Rabies = cracked ignition coil or bad plug wires. It ONLY occurs in raining day.
AKA Beantownbug
Old 10-11-2006, 02:45 AM
VA,
Car: 98 New Beetle
took plug #2 out..it was completely packed with crud. the plug was in there about 3 days. either i picked up a bunch of gunk installing it or there was some fouling in the cylinder that kicked up. running smooth now but i ordered a new coil from Rockauto for $69. hopefully that will clear up any of the pending code issues when it rains.
Old 10-19-2006, 02:19 AM
jazzcat's Avatar
Delightfully Tacky
Mesa, AZ, USA
Car: 1997 GTi VR6
are you sure the cel was flashing? thats only supposed to happen when the catalyic convertor is failing
Jim
1997 GTi VR6..its cliche
http://rustisnotacrime.com
Old 02-16-2009, 12:49 AM
Stonewall, MB, Canada
Car: 2000 beetle 2.0 GLS
The CEL will flash if the OBD II system detects a continuous mis-fire. Driving the vehicle while this is happening sends un-burned fuel into the cat. converter, causing it to run VERY hot which can cause it to melt or break-down.
If the problem is corrected soon enough, the cat. converter won't suffer permanant damage.
This applies to all makes of vehicle with an OBD II system.
This data logger really works on the bug, check it out!
http://www.crecorder.com
Old 02-26-2009, 01:54 PM
Genesis's Avatar
Virginia Beach, VA, USA
Car: 2000 GLS
Default Engine mis-fire
I had the same problem happen to me also. I changed the spark plugs and ingnition coil and the problem went away. The ignitions coil had burned out and fouled out the spark plug. I was able an ignition coil shipped overnight from www.germanautoparts.com for a very good price.
Old 02-28-2009, 08:58 AM
LadybugEwa's Avatar
Bug me again!
Toronto, Ontario, Canada
Car: 2012 Turbo, RED of course!
Misfiring when it rains is 99.9% of the time - guaranteed to be the coil.
The age of yours is 'just right' as well.
On the Vortex there are numerous posts describing how the crappy plastic coil housing develops hairline cracks from age and multiple cycles of heat. They also posted a 'JB Weld' fix for it that you can do if you have a day when you don't need to drive the bug, to let it cure. Or if you don't have the luxury of taking the car off the road for a day, buy a new coil and put it in yourself. There's an excellent DIY thread on the Vortex, and though it features an AEG-engined Jetta, the only variation for the bug is that the SAI bracket DOES need to come out to remove the coil. I found it pretty easy, and I'm no mechanic, just reasonably handy with a wrench (for a girl).
Here's a look at Ladybug
Old 03-10-2009, 05:17 AM
Lnzbug's Avatar
Arlington Heights, IL, USA
Car: 2012 Beetle+ 2001 blue vortex 1.8t + 1971 vert + 68 bug & 71 & 78 buses
Is it safe to say if one is bad the others will go too? Should I replace all the coils or just the one that's bad?
Old 03-10-2009, 06:01 AM
Genesis's Avatar
Car: 2000 GLS
Exclamation 1.8T Ignition Coils
My wife has a 2003 Passat with the 1.8T and two went bad a year ago. I replaced all four when the the CEL came on. In my opinion, if one or two are going bad now, then the others are sure to go in the very near future. Just my Humble Opinion...
Old 03-10-2009, 06:09 AM
Lnzbug's Avatar
That's the way I think but the hubby doesn't like to open the wallet that wide
Old 03-11-2009, 04:11 AM
Genesis's Avatar
Car: 2000 GLS
http://www.germanautoparts.com/Volks...lectrical/57/4
This is probably the best price for brand new Ignition Coils for the 1.8T.
Old 03-11-2009, 10:20 PM
Lnzbug's Avatar
Thanks. I actually got them for $28 each at the dealer. First he said $32 then I asked if he could do better he did! Then, when John went to put them in (I bought 4) they were the wrong ones I went back today with an old one & they only had 3. He also said they were $1 each more but we would just do an exchange. I should be buggin again tomorrow.
BTW, my CEL was flashing too.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
CEL + rattling under car = bad catalytic converter? scooter Questions, Issues, Concerns, or Problems with the New Beetle 19 06-12-2007 03:35 PM
Is this 2.5 a version of the old Audi 5 cyl.? bockegg 2.5 Liter Gas 22 08-14-2006 03:02 AM
Wont start, P0301 tonybalido 2.0 Liter Gas 11 08-01-2006 11:56 PM
Fully Automatic Car: Can Drive Up To 150 MPH - All On Its Own BlueMartian Miscellaneous Hoo-Ha Archive 3 07-02-2006 05:17 PM
P0301 Cylinder 1 Misfire Detected Bugged in CA 2.0 Liter Gas 5 12-16-2005 08:25 AM
