Seat Belt Tensioner switch.....where is it? - NewBeetle.org Forums
Old 10-16-2006, 01:59 AM
MN, USA
Car: 2002
Default Seat Belt Tensioner switch.....where is it?
Hello Everyone. I've been a lurker here for some time. A little over a year ago I bought my lovely girlfriend Karen a 2002 Beetle and joined this site to learn about these cars and their personalities. I just changed the precat O2 sensor on her car and the CEL is now off. But her airbag light is on, and the scanner says it's the left side seat belt tensioner switch. I was hoping it was just a bad connection and cleaned up all connectors I could find under the seat hoping it would fix it. I have two questions. 1. - Do you need a special tool to clear the codes for the restraint system? 2. - Just where is this tensioner switch? I'm not a mechanic but I do maintain my Audi A8L and I'm also lucky enough to own a Ferrari Testarossa - I do all of my own engine-out services and stuff. So I'm not shy about getting dirty. Any help would be appreciated. Thank You Everyone. Sincerely - Jeff
Old 10-16-2006, 04:29 AM
btb's Avatar
btbNewBeetle.org Member Sponsor btb is offline
Boston, Mass, USA
Car: MY00 2.0SC, MY99 TDI
1.Yes, it's called vagcom.
2.see picture below.
Disconnect the battery before doing ANYTHING with the airbag system.
AKA Beantownbug
Old 10-16-2006, 06:33 PM
75 year old car nut
Tucson, AZ., AZ,
Car: '99 NB-GLS--"85 Cabrolet
Default Vagcom
Thats a cute picture of all the parts, but no listing of what they are???
Earl
75 year old car nut
Old 10-16-2006, 06:39 PM
btb's Avatar
Boston, Mass, USA
Earl
I excerpted it from the Bentley manual. Just to point out where it is.
Old 10-16-2006, 10:39 PM
MN, USA
Car: 2002
btb - THANK YOU VERY MUCH !!!
Old 10-16-2006, 10:44 PM
MN, USA
Car: 2002
btb - THANK YOU VERY MUCH !!! I appreciate you taking the time to post that assembly drawing - I understand now. I have a cheapie Geni-scan tool that can scan and erase some codes. But I suspect it will not erase anything to do with the airbag or supplimental restraint system. I'll start looking at purchasing a vag-com tool - which will also help me on the Audi A8L.
My girlfriend installed some seat covers - and shortly there after the airbag light came on. We have tried to reseat all connectors and disconnet the battery - but the light persists. In the near future I'll pull off the interior panel and see what's up. I can't imagine what could have set off this dog-gone idiot light!!!!!
I hope others can chime in with their experiences in this area.
Old 10-17-2006, 03:54 AM
btb's Avatar
Boston, Mass, USA
carguy, my pleasure The airbag light is different from others in such a way that once it sets off, it's there. The only option is to use vagcom to reset it. I wish you were closer so I'll reset it for you. Search for people with vagcom that will offer help here:
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl
Old 10-18-2006, 07:39 PM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
I have a similar scan tool and it says the same thing. The tensioner is located in the pillar behind the door. I have not played with mine ... the tensioner is quite expensive for the drivers side ... guess that is the one that gets replaced the most in an accident. They are also not just electrical instead of mechanical ... they are ballistic. I will check mine with a VAG ... but don't expect any difference, when mine came on I had the passenger seat folded forward, that was like 2 years ago.
Old 03-28-2009, 06:47 PM
Miami, FL, USA
Car: GLX 2001, Dark Blue, Standard Trim
Side airbags in the seats? Its not in the pillar but part of the seat belt clasp. Error code is 00591. I had to replace the clasp once already and looks like second time unless I can fix it myself. Some sort of short or broken wire I think and its a pig to get off of the seat itself to check
Seat belt switch / airbag light Dreamspinner 1.8 Liter Turbo 6 08-03-2006 10:52 PM
Timing Belt Tensioner Removal Question GLXpress 1.8 Liter Turbo 1 06-12-2006 08:23 PM
Get rid of the hydraulic tensioner (timing belt) Buggin 1.8 Liter Turbo 3 03-21-2006 04:59 AM
toothed belt tensioner sequoiagrapeboy 2.0 Liter Gas 1 01-27-2006 11:20 PM
belt tensioner tonysailor 1.9 Liter TDI 2 01-24-2006 07:50 PM
