Christine? - NewBeetle.org Forums
Old 10-16-2006, 04:37 AM
veedub00's Avatar
Eastpointe, MI, USA
Car: 2000 GL Yellow
Default Christine?
What's this mean?
I was at a stoplight and my engine was revving by itself. In drive with the brakes applied it was about 1500 rpms and when I put it into neutral it went to 3500 rpm and kept bouncing between 3000 and 3500 rpm.
After a quick freeway jaunt it was normal idle in my driveway.
What is doing this? It happened once before.
Thanks,
James
Old 10-16-2006, 02:03 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
Automatic or manual? I've seen this occur before but I don't recall what the solution was.
Phoenix: 2003 Uni-Red New Beetle GLS TDI 132k former-automatic with a 1998 TDI Manual Transmission swap.
Old 10-16-2006, 02:07 PM
vdubbugman53's Avatar
Arvada, CO, USA
mine was a temp sensor i belive....i was told that the engine reves to try to coolits self down
Old 10-16-2006, 05:11 PM
Mr.Yellow's Avatar
I am McLovin
Bellingham aka Bham, WA, USA
that dosent make sense that would make it hotter, not cool its self down
Old 10-16-2006, 07:33 PM
veedub00's Avatar
Eastpointe, MI, USA
Car: 2000 GL Yellow
Temp sensor, makes sense. My temp light blinked on a little when i first started the car and went off about 30 seconds later. Interesting. Thank you.
James
Old 10-16-2006, 08:17 PM
spdnbeetle01's Avatar
Built 4 Sin !
Moreno Valley, CA, USA
Car: 2001 New Beetle GLS
If you drive an automatic...it could be the temp sensor or the MAF sensor. Try changing out the Temp sensor ($19 bucks) and clean out the MAF with MAF cleaner by CRC products ($5 or $6). Mine did the same thing. Although mine was a 5 speed, it did the trick, and my light never blinked again, the ruff idle stopped, and my mileage shot back up like it was new, well almost new LOL!
P.S.
Was it blinking blue in color...if it was red in color...be sure to check the fluid level. If the fluid level is fine...I would do a radiator flush and install a new Temp sensor & clip. No problems for me after that!
I'm in love with a white chic on four rubbers
