Several stalls after starting - NewBeetle.org Forums
Old 10-17-2006, 04:01 AM
IceDog's Avatar
((( XM )))
Mississauga, Ontario, Canada
Car: 2k Techno Blue Beetle
Default Several stalls after starting
Recently I have had my 2000 2.0 stall or die right after starting it. Once was an easy restart, the other took several seconds (about 10) of cranking. This has never happened before and was wondering if it is a sign I need to change the fuel filter.
Also, the check engine light has come on and gone off twice in the past month for unknown reasons. I quickly stopped the car and checked the fluids, of which all were fine.
I guess while I'm posting I should ask this as well. Anyone know what I will have to change on my beetle moving to Canada? And will the extended warranty I have on it be honored??!!
Any suggestions?
IceDog
2000 TechnoBlue
59,000 miles
Old 10-17-2006, 02:46 PM
vdubbugman53's Avatar
Arvada, CO, USA
mine did something like that and yes ther fuel filter fixed my problem....the check light well who knows you would have to ask the car and see what it says.....the codes should be stored if you do get it scanned
01 2.0L Starting Problems TechnoBlue 2.0 Liter Gas 13 10-13-2006 06:16 PM
Hard Starting...... halfinchstars 1.8 Liter Turbo 11 08-15-2006 03:01 AM
Beetle Stalls Every Morning holysweetheart Questions, Issues, Concerns, or Problems with the New Beetle 2 08-10-2006 04:29 AM
trouble starting!! bluebeetlebabe 1.8 Liter Turbo 4 06-11-2006 06:15 AM
feels like i'm starting over callisto9 New Member Forum 20 09-27-2005 04:53 PM
