Coolant - NewBeetle.org Forums
Old 11-03-2006, 01:32 AM
Default Coolant
Just had the timing belt, water pump, coolant reservoir , strut mounts and front brakes done on my daughters 1998 NB with 103K. I noticed that the coolant doesn't have the pink coolant in it. I guess the G12 coolant was not used. My daughter needs to return to college tomorrow. What can I expect if teh G12 coolant is not used??? My indepenednt mechanic that services my Volvo did the repairs.
Old 11-03-2006, 07:20 AM
Knoxville, TN,
Short term, no major issues... long term, a dead engine.
Starting in mid 97 VW/Audi went to the "G12" coolant which is most of the time pink in color (there is a purple version that I've seen a few times that has come from the factory). Any coolant you get over the counter from the part dept will always be pink in color.
If you mix a G11 and a G12, they it will turn the coolant into a solid that clogs up the system so that coolant can not flow, thus over heat the engine and warp the head. I've seen this more than once.
You need to have the coolant system flushed (not drained, FLUSHED) and then the correct G12 coolant put into the system.
I've had the pleasure of doing just such a task many times where where Jiffy Boob and such have put in the wrong coolant.
Later.
Pencilneck blah blah blah
OEM Wheel Database....
5052 @ $8000 = total crap
VAG COM @ $350 = sanity
Old 11-03-2006, 11:55 AM
Default coolant - what is G11
Thanks for the reply. My daughter has about 250 miles back to college then she returns in 2 weeks. I can have the coolant flushed then. The coolant my mechanic put in is not the normal limegreen color, but slightly purplish. I will ask him today what it is and whether it meets the specs of G12. His shop works on Volvos, BMW and Mercedes.
BTW what is G11 coolant?
Thanks
Old 11-04-2006, 05:51 AM
180 Degrees out of faze
Central Coast, CA,
Car: 98 TDI NB.
G11 is the old style "green" coolant like you would pick up at AutoZone.
Old 11-04-2006, 07:11 AM
btb's Avatar
btbNewBeetle.org Member Sponsor btb is offline
Boston, Mass, USA
Car: MY00 2.0SC, MY99 TDI
G11(green) + G12(pink)= NO
G12(pink) + G12+(purple)=OK
Moreover,G11, G12 and G12+ cannot be mixed with anything but distilled water.
AKA Beantownbug
Old 11-04-2006, 05:33 PM
mezonesxbox's Avatar
Beetle maniac
Newport Beach, CA, USA
Car: New Beetle 2000 GLS, Audi A6 2000
Just use water.... unless if you really need the atifreeze. I live in CA so i really never use antifreeze...
Old 11-04-2006, 05:40 PM
btb's Avatar
Boston, Mass, USA
A quote from Bentley:
"Coolant additive G12 prevents freeze and corrosion damage, lime deposits and also raises the boiling temperature. The cooling system must contain G12 coolant additive the entire year regardless of the climate."
Mixing ratio of G12 with distilled water 1:1 is recommended.
Old 11-07-2006, 01:57 AM
wasting my time in Cancun
Cancun, Quintana Roo, Mexico
Car: 2003 New Beetle GLS 2.0 Stick
always use the G12 coolant
G12 coolant montague Questions, Issues, Concerns, or Problems with the New Beetle 16 08-03-2006 11:40 AM
Leaking Coolant, Help!!! GraceIsotope 1.8 Liter Turbo 3 07-27-2006 11:22 PM
Leaking Coolant, Help!!! GraceIsotope New Member Forum 5 07-27-2006 11:18 PM
Coolant flush ms03bug 2.0 Liter Gas 8 01-03-2006 09:30 PM
All you ever wanted to know about coolant.. rcy Questions, Issues, Concerns, or Problems with the New Beetle 4 12-19-2005 01:50 AM
