Engine turning over followed by a brief screeching noise - What is that? - NewBeetle.org Forums
Old 11-03-2006, 08:57 PM
ptmlinh's Avatar
San Jose , CA, USA
Car: 2000 2.0
Unhappy Engine turning over followed by a brief screeching noise - What is that?
Hi guys, so here's this problem I've recently run into. Once in a while when I turn the ignition to the on position and the engine turns over, there's this brief screeching "ekkkkkrekkkkk" noise, which sounds like the noise when the engine is already on and you turn the ignition again. It does not happen everytime I start the car, maybe 2 out of every 10 times, never in a row, and can never be expected when it's going to happen. Has this occured to anyone?
Another thing I'd like to ask for your insight is this pull when the car slows down, i.e., if I'm approaching a red light, I step on the brake, the rpm slows from 3000 to 1000, around some points in that range it would rev up to 1500-2000 causing this brief pull. I know it's not the brake because it happens even when I don't apply the brake. This eventually fades away (i.e., first red light rev from 1000-1500, second red light 1000-1200, and finally to a point where you don't notice it any more, then disappear, no more pull after a couple blocks) But the thing is it happens eveytime I start the car, it doesn't matter if the engine is cold or hot, I would drive a couple blocks and it would go away.
Help me !
Old 11-03-2006, 09:30 PM
noR's Avatar
Administrator
Jackson, MS, USA
You need a new starter.
noR | me | Phrog
PHROG
Old 11-04-2006, 02:07 AM
yellow99's Avatar
Finch the BUG LVR!
Barrie, Ontario, Canada
Car: 1999 GLS
i currently have the same problem, I asked one of my buddies who is a certified vw tech and he also said its the starter, however I'm gunna wait a bit to get a new one.
Yellow99 - GTS Eyelids, NEUSPEED P-FLO Intake, Magnaflow Cat-Back Exaust, X3 Racing LED Tail lights, TVA Dashkit
See my New Beetle click here
Finch http://bugboy994.tripod.com/
Check out my drawings! www.wix.com/yellow99/cardrawings
Old 11-04-2006, 05:14 AM
Bob's Avatar
BobRegistered Member Bob is offline
Grand Poobah
Weyburn, Saskatchewan, Canada
Car: 2000 Batik Blue GLS
Mine does it to. Has since I got it I think... I just stopped paying attention becuase everything is still working good after 8 months... I thought it was normal
Old 11-04-2006, 05:37 AM
btb's Avatar
btbNewBeetle.org Member Sponsor btb is offline
Boston, Mass, USA
Car: MY00 2.0SC, MY99 TDI
Either you clean and lube the starter or replace it will solve the noise problem.
AKA Beantownbug
Old 11-04-2006, 09:44 AM
ptmlinh's Avatar
San Jose , CA, USA
Car: 2000 2.0
Okay, so it'd be most likely the starter. The part itself to be replaced is pretty pricey though . Does anyone know anything about the second problem? Thanks for all the input guys !
2.5 Engine Area Noise blackonblack 2.5 Liter Gas 3 10-24-2006 02:38 AM
"creaking" noise when turning DWRAT Questions, Issues, Concerns, or Problems with the New Beetle 20 08-12-2006 05:20 AM
engine noise adam454c 2.0 Liter Gas 5 06-17-2006 03:36 AM
Clunking noise when turning in reverse.... Turboboy Questions, Issues, Concerns, or Problems with the New Beetle 2 05-12-2006 02:11 AM
Transaxle noise when turning left fatbob 2.0 Liter Gas 1 11-24-2005 11:40 AM
