Torque Specs - NewBeetle.org Forums
Old 11-27-2006, 07:18 PM
Default Torque Specs
Can anyone tell me the torque specs for the cyclinder head on a 98 beetle??
Thanks!
Old 11-27-2006, 10:36 PM
SilverSportNOLA's Avatar
Faster Than Katrina
Formerly New Orleans, LA, USA
Car: 01 Sport
If nobody has gotten this for you I will look it up and post when I get home.
Old 11-28-2006, 12:35 AM
Faster Than Katrina
Car: 01 Sport
Here is what you need according to bentley ... and heed the warning about piston/valve collision avoidance.
Tighten cylinder head in tightening sequence as follows:
- Pretighten all bolts to 40 Nm (30 ft lb).
- Tighten all bolts 1/4 turn (90) further using a rigid wrench.
- Tighten all bolts a 1/4 turn (90) further.
Note: When the camshaft is turned, the crankshaft must not be at TDC. Danger of damage to valves or piston crowns.
Old 11-28-2006, 12:37 AM
Faster Than Katrina
Car: 01 Sport
Sorry ... That was the image for the loosening sequence. Tightening is the following.
Specs? PunkinBug Styling Modifications 13 11-15-2006 08:06 PM
break specs A. Onassis 1.8 Liter Turbo 0 04-15-2006 06:25 PM
Trying to get some specs 01GLXTURBO 1.8 Liter Turbo 12 12-31-2005 01:44 AM
2005 Beetle specs :) The Cheat Technical Modifications 0 09-23-2005 03:14 AM
