We have a 1999 VW Beetle, 2.0 gasoline engine, automatic transmission. We bought it about 7 months ago for our daughter's High School graduation.
It had just been to the VW service and the check engine light was on saying bad MAF sensor. We replaced the MAF sensor and the light came on a few weeks later, MAF sensor again, the light has stayed on since then but it seemed to run fine. A couple weeks ago, our daughter was driving it back to college (in the rain). It started "jerking" and didn't want to go up hills. She had just filled the gas tank so we thought she got some water in the gas. She put injector cleaner in it and continued on her trip and it seemed to straighten up. The next day, I put gas in my old truck at the same station where she had gotten it and the pump ran super slow as if they were almost out of gas. So this sort of confirmed to me that she had just gotten gas with water or trash in it. We were driving the Beetle a few days ago (in the rain). And it started "jerking" again while going up a hill, the check engine light also flashed a couple times. It seemed like it could not decide which gear to be in. It finally got to the point it would only run if you pumped the gas pedal. Then it finally died and would not stay running. It will start every time, but will not stay running, give it gas, it dies, dont give it gas, it dies. We hauled it home on a flatbed trailer, replaced the fuel filter and it still does the same thing (starts but wont stay running). Took out the air filter and it was soaked with water so much that you could have rung it out and there was no less than a cup of sand under the air filter (I assume from the roads being sanded during a recent snow storm). This water and sand was not there when we replaced the MAF sensor 6 months ago (but it wasnt rainy then either). So, I was wondering if anyone else here has had a problem with their Beetle sucking water into the intake like a shop vac? And any ideas of what could be causing it to start but not stay running? Our daughter needs it to go back to college first part of January. And we dont have a ton of money to spend on a mechanic. I figured we would start with the MAF sensor and go from there. Suspected the catalact converter too but have never heard it make any noises that point to that. I borrowed a scanner from Oreillys Autoparts. Got the following codes, P102 and P304. Cleared the codes and started the car a couple times, then scanned again and only got the P102 code. The guy at Oreillys looked the codes up in the book and said that P102 was the MAF sensor and P304 is cylinder 4 misfire. If the coil pack is bad, would it still start? It starts perfectly every time, but dies right after starting. Added fuel drier to the gas tank and let it sit overnight, still doing the same thing. Sometimes the car runs longer than other times by pumping the gas pedal. If we disconnect the MAF sensor and my husband holds his hand over the hole (almost covering the whole thing), it will stay running without pumping the gas pedal. |
Did she drive it into a lake or something? I find it hard to believe sand got past the filter let alone a cupful of sand. something is fishey if you ask me. are you sure you didnt buy a flood car from katrina because that would be my second guess.
![]() I had a second thought the only way this could happen is if the inner wheel well is actually damaged or missing allowing the front drivers wheel to continually throw water and sand into the snowbox which is where the motor gets its air supply. I will hunt up the snowbox thread and post it here for you in a few minutes. Heres the thread. How-To - Snowbox Removal also this thread. http://newbeetle.org/forums/technical-modifications/4103-anyone-has-pictures-what-snowbox-post51290.html Last edited by gilligan; 12-25-2006 at 10:53 PM.. |
Something to check is the high voltage circuits. With the car running, and in dim light, mist water over the spark plug wires, and coil pack. Look for blue sparks. If you see the wires sparking (look at number 3 closely), they need replacement. If the coil pack show sparking, then inspect for cracks. Some people have been able to "fix" the problem by filling in the cracks with epoxy. Otherwise it needs to be replaced.
I have been accused of many things, sane is not one of them. |
Will the MAF cause the engine to not run? I don't think it would.
Would sucking water across the MAF cause the MAF to fail? I bet it would. Would sucking water into the engine damage it so it won't start? Possible. Pull the spark plugs disable the coil and crank over the engine. See if your engine turns into a water fountain. Hopefully it won't.
TDI No start troubleshooting. |
I would go for plugs and wires and coilpack being the problems ... as for the water ... it must not have the inner fender in place. I wasn't too close for Katrina, but have not gotten either sand or water into my airbox, I don't have the snowbox anymore. Find where the water is getting in, from what I remember of the snowbox ... you can fill it up and then the engine will become a waterpump. If you have the inner fender liner, check the area around the headlight on the drivers side ... water can be forced in past the seal while driving.
Pull the plugs and spin it over to spray out any water in the engine, once you solve it change the oil ... water would get down there if the pistons saw water. As for the MAF .... solve the cause of the problem first, you can disconnect the MAF and still drive the car, will burn a little more gas, give you a CEL and ESP will not function ... but better than keep on replacing it till the problem is solved. |
I have ordered a coil pack for it and bought new spark plugs. Going to try some of the suggestions you guys posted. Will post results. Thanks to everyone for their input. |
Ok,
I took out plugs and turned it over, no water coming out. Removed the snow box, had trouble getting it out from under the fender, so I cut the rubber hose that connects the two parts together. There was mud completly blocking the inside of the rubber hose. Can't keep it running long enough to spritz the coil and wires with water. That'll have to wait until hubby is home from work to help! It smells like it is not burning all the gas, and sometimes it tries to back fire if I pump the footpedal a lot. So maybe the coil is not putting out a hot enough spark. I ordered one anyway so I guess we will know when it gets here. I do see a crack in the coil where one of the screws holds it on. |
You also need to clean out the airbox and changed the air filter. If the filter is not letting air pass through you won't get it to run for long. Order the fender liner also. Hopefully the tabs are still attached around the fender to bolt it into ... if so make sure the captive nuts are there, you will probably need the bolts to .... best bet is to get it from a junkyard. Any right side beetle ones should fit except from the TurboS.
Yep, already cleaned out the airbox and put in new filter. |
I dont have a way to do a compression check, when I had the plugs out, it sounded like it had lots of compression, LOL. I scrunched up a paper towel and placed it over one of the spark plug holes and it blew it off (I was trying to catch any liquid that might come out of that hole while cranking). |
Well ... at least it blew the rag out .... instead of sucking it in. You may need to pull the intake tubing all the way and take a look at the throttle body. I am not a 2.0 Expert ... but I believe the throttle body is cable driven, so less electronics to short out ... but if it is drive by wire like the 1.8T ... that could be a problem also. Be sure to disconnect the MAF and try getting it running. Hopefully it didn't take a few big gulps of water and ruin the Cat Converter. Try getting someone on the tail end when you can start it ... to see if there is exhaust coming out of the tailpipe. It would still happen if the cat is clogged, and might not be noticed till the higher RPM levels.
Have you tried running it with the air cleaner competely removed? Just take it off at the MAF and see if it runs. This gets rid of all of the air system before the filter and will help you narrow things down.
If you see a crack in the coil pack (that's for those spark things, right? ) then it's probably cooked bread. In other words: Toast. Maybe there is a frined nearby that has a 2.0 in any VW that can loan you theirs for testing? If you do this, be sure to install yours in theirs to see if thiers acted like yours did. |
Good Luck. |
That would have to be a pretty good friend to let me put a crappy coil pack in their car and risk damage, LOL. But seriously, I dont have any friends (with a VW that is, LOL). I have the coil pack ordered (cant get anything around here). And the place I bought the MAF sensor from (1stvwparts.com)said it was still under warranty, so if I mail it back to them, they will send me a new one. Last edited by abrison; 12-27-2006 at 07:35 AM.. |
| won't stay running | cockroach | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 11-05-2006 04:14 PM |
| won't stay running | cockroach | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 11-03-2006 11:47 PM |
| 98 NB hard to start wont stay running. code 1543 | magic.42 | 2.0 Liter Gas | 11 | 06-22-2006 08:00 PM |
| My beetle never wants to stay clean! | importsaremylife | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 05-18-2006 01:57 AM |
| Does Beetle stay unlocked? | hooch66 | Questions, Issues, Concerns, or Problems with the New Beetle | 9 | 12-13-2005 01:39 AM |
