you also need a 10mm socket/extension to remove the power steering reservoir from its mount. it is in the way directly ro the left of the battery. once those two are loose, and the cables are disconnected, the battery pulls out to the left a little then you can tilt it up and out of the way.
reinstall the new battery the same way. tilt in, then slide over then bolt down. reattach the power steering reservoir and reattach the battery cables. if you are feeling frisky you could remove the 3 bolts under the battery to remove the tray and clean up the grounds that are under there too. this is of course after you remove the old battery and before you install the new one. good luck!
There are a couple How-To's in the Technical How-To section if you need images and stuff.
Thanks. I forgot about that part. Last one I changed was in a Jetta and the reservoir is elsewhere. ![]() |
| Bolt pattern??? | WNAB911 | 2.0 Liter Gas | 10 | 07-04-2009 01:03 AM |
| Crank Balancer Bolt | mc63 | Technical Modifications | 0 | 09-09-2006 08:37 PM |
| Stripped bolt | lawlesseyes | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 08-28-2006 08:52 PM |
| Fs: Mk4 Bolt On Parts | Zookie | The Canada Corner | 7 | 05-03-2006 04:49 PM |
| Fs: 1.8t Bolt-on Performance Parts | Zookie | The Canada Corner | 12 | 04-14-2006 09:25 PM |
