P0102 & P0112 codes, and other questions - NewBeetle.org Forums
Old 01-18-2007, 02:08 AM
Gotlift02's Avatar
Wicked Customs
Naples, FL, USA
Car: 2001 Beetle/2002 Jetta
Cool P0102 & P0112 codes, and other questions
Im throwing no CEL, but still pulled these codes out of a ill-running 2000 2.0 beetle. Its slower then normal and getting crappy mileage..
Checked stock filter, its clean, noticed that someone drilled holes in the lower right half of the air-box.. No biggie, just more intake whoosh.. Changed out the belt, and belt-tensioner (B.T's bearing was bad)..
I pulled these codes out of it, no CEL but still pulled these codes..
P0102- Mass or Volume Air Flow Circ Low Input
P0112- Intake Air Temp.Circ Low Input
Now, if this is the same as my TDI jetta, the codes listed above are directly related to a bad MAFS (Mass air flow sensor) , am I wrong? I know that they are crappy...
I unplugged the sensor, and it definetly picked up in speed.. I think its out.. I also noticed that the actual plug (Male side) the inside of it, which is red, is partially missing, is that going to be ok?
This is my wifes car, we bought it with 13k on it, 2 years ago, and now it has 38k on it.. Anything else I should be worried about?
Thank you
-Jordan
Wicked Customs
www.wickedcustomsonline.com
wickedcustumz@hotmail.com
Wifes 2000 Silver Beetle 2.0
-17" Audi RS6 Rims -Ryken Tires
-20mm spacers -Custom pink VW emblems
-Hook spoiler -Phatnoise
-Pink Aztellas -Pink Headliner
-Pink Interior Accents
Old 01-18-2007, 02:02 PM
angelworks's Avatar
Write it like it's hot!
If I can make it there--NY baby, USA
Car: 98 Red 2.0 ,5 speed -70K
Sounds like the MAF.
It's an easy change out if it is.
Any other thoughts anyone?
Drive it like you mean it!
My Greenie Blog
Body in the United States/ Heart in Ireland ~~~ Princess Poppy 1998 5 spd Red
Old 01-18-2007, 06:42 PM
Gotlift02's Avatar
Wicked Customs
Naples, FL, USA
Yeah, its definetly easy.. Ive changed out a total of 5 MAFS in my TDI jetta (Kept getting bad ones..), and 1 in her 2.0 at 18k, now she has 38k, and its mileage isnt so hot... I dont have my vag-com up and running anymore, which I need to do, otherwise id check the parametors of the O2 sensors, and MAFS as well. But I kinda have to shotgun it with the OBII Scanner I have.
I also noticed when I had the car running and I dis-connected the mafs that the car sputtered like it knew what was up.. Ive never seen that before..lol, not even in my TDI..
Any other clue on why her power and mileage are down? clogged cat at 38k? 02 sensor? Stock plugs gone? No mis-fire codes, and a little spudering at idle.. Otherwise it runs smooth as can be..
-Jordan
2002 GLS 2.0L engine codes AVH & AZG Skoobahead 2.0 Liter Gas 2 01-22-2011 02:09 PM
GPS Navigation Units: Recommendations & Questions soccerbug Miscellaneous Hoo-Ha Archive 13 12-18-2007 05:16 AM
need help with codes bobaganoosh 1.8 Liter Turbo 6 12-30-2006 04:50 AM
CEL & Secondary air pump Questions Cadenza 1.8 Liter Turbo 4 06-12-2006 05:17 AM
e-codes tjd Technical Modifications 0 01-20-2006 10:30 PM
