Battery/Generator Light - NewBeetle.org Forums
Old 01-24-2007, 05:42 AM
DalRegistered Member Dal is offline
Car: 2001 2.0 L LS
Unhappy Battery/Generator Light
I've searched the forum and could not find another post discussing this so...
While driving to work today, my Battery/Generator light came on. There are no strange noises coming from the engine comartment and the car seems to be driving fine. The belts seem to be OK and the battery is not draining after the car had been parked for 8 hours.
What can be the problem as the owner's manual is of no use? And, more importantly, is this gonna be another $1000+ repair?
Old 01-24-2007, 01:28 PM
speedie's Avatar
Eine Kleine Panzer
Lampasas, TX, USA
Car: 1968 Bug 2001 New Beetle 1.8T 2003 New Beetle 2.0
I would have the battery load tested and have the charging system checked (this checks the ability of the alternator). Places like Autozone can do this for you on the spot. Your alternator may be going bad, but it is currently able to keep up. A load test and a system test will at least eliminate them as possibilities.
You may want to get this done sooner rather than later lest you will be stranded or your car will go kaput will you are driving.
Old 01-24-2007, 03:20 PM
kcfoxie's Avatar
I'm not a girl. Sorry!
Durham, NC, USA
Car: 2003 New Beetle TDI
I agree w/ speedie.. it may have come on because of a drop in voltage from the alternator. if it is the alternator, it's not a hard replacement.
Old 01-24-2007, 03:57 PM
noR's Avatar
Administrator
Jackson, MS, USA
Get it checked out SOON.
Faulty generators can cause broken batteries.
noR | me | Phrog
PHROG
Old 01-28-2007, 05:39 PM
our alternator(not generator, unless it's a bike )went around 100k, pretty easy install for a VW.
autozone rebuilt is around 200 with core return, there's two kinds, one came with a polished pulley and one doesn't. the one with the pulley doesn't have a proper electronic port, i ended up slicing and solder some wires.
so make sure you get the one with the right connector.
btw our bug is a 98
if you have a multi-meter you can check the voltage at idle, then bump up the load by using high power items like high beam, a/c,etc, the voltage will drop a bit, if the alternator is going south, it will not able to bump it back to sub 14ish volts.
or
you can just bring it to autozone
What's in the garage
Mazda Miata(daily)
Honda S2000 (weekend)
Honda accord (turbo'd, parted and sold)
Acura Legend (sold)
www.honda-tech.com
www.s2ki.com
www.miata.net
Brake Light, Check engine light, air bag light, but wait theres more djack19 Questions, Issues, Concerns, or Problems with the New Beetle 15 11-09-2011 10:13 AM
The Pirate Name Generator Oyveychris Quizzes 35 04-03-2010 09:56 PM
How To - EPC light/Brake light switch install Audiophil Technical How-To 18 09-22-2007 02:25 PM
Slogan Generator Yellow Turbo Jokes 27 08-01-2006 09:59 AM
Battery Light? GaUdeNtiUs 2.0 Liter Gas 7 04-07-2006 05:09 AM
