My girlfriends 2000 Beetle has a strange idle. It feels like it is sputtering, it also shakes the car. This morning her car would not start (thanks to sub zero temperatures) I got it started and running. I was going to take it for a good drive to let everything warm up but after my first light it wouldnt want to accelerate. It took about 5 seconds to actually accell. It got a little better after some more driving but it isnt the same. What are these problems and how can I fix them? There is only 42K on the car.
The only thing I can think of would be condensation.
Does this only happen when it's cold?
i only heard of 30K intervals for maintenance. but that is at ford. i was going to put new plugs in and fuel injector cleaner but she just had the car in for service and wound up with a 500 bill. she hit a chunk of asphault and it broke open her oil pan. i could have done it for her but it would have taken longer.
Okay, then it sounds like it's time to catch up on the maintenance.
40K on a 2.0 is plugs & wires [get the tool or you'll work too hard on the couple in the back]. brake fluid flush. check the brakes so you know how close/far you are from out. Change the air filter, and the cabin air filter. ... I think that's about it. See if the normal maintenance fixes the problem. before throwing other parts at it. |
Beetles aren't really that bad on coilpacks.
![]() 01-03 had some bad style, lots of bad coilpacks on the 1.8t's ... but I don't think the coilpack on the 2.0 caused alot of problems. I could be wrong though I suppose; just doesn't seem nearly as widespread as some problems. |
so here are the codes i got...
P0172 (bank 1 too rich) P1255 ( pedal correlation low?????) P0300 (multiple misfire) P0440 (EVAP malfunction) P0304 (misfire in #4) P0134 (insufficient activity from O2 #1 in bank 1) P0139 (slow response from O2 #2 in bank 1) how could all of these things go wrong? i am going to replace the plugs, wires, fuel filter, pcv. i dont know what else to do, anybody know? |
I don't think pcv is the problem. O2 is definitely a problem...I can't remember if bank 1 is post cat or not. You could be getting a misfire from a bad plugs, wires, or a pack (multiple misfire because pack is not giving juice to the wires). Or it could be misfire from inappropriate fuel-air mixture due to bum O2 sensor (insufficent activity/slow response). The too rich is prolly from the misfire.
Don't trust it...sometimes a component going bad will cause an intermittent CEL. Then, one day it goes out and you get a persistent CEL. Seek to get the problems fixed and you and your car will be happy.
| Rough idle after accident | DizzyV6P | 1.8 Liter Turbo | 5 | 07-13-2006 04:27 AM |
| help, no a/c, rough idle, overheating!! | a_masters | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 06-18-2006 12:26 AM |
| Rough Idle | rjs77 | 2.0 Liter Gas | 0 | 05-07-2006 10:26 PM |
| Cold Misfire/Idle rough | blackonblack | 1.8 Liter Turbo | 2 | 04-02-2006 04:31 PM |
| Rough Idle? | SMG | 2.0 Liter Gas | 10 | 02-19-2006 03:35 PM |
