Po116 - NewBeetle.org Forums
Old 02-22-2007, 05:36 PM
San Marcos, TX, USA
Car: 2003 VW Beetle-plain jane with potential
Default Po116
Can anyone tell me what PO116 means??? Or where the cooling fan fuse is???
Old 02-22-2007, 05:42 PM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
fuses for cooling fans are located atop the battery inside that funky looking fuse box. Look for signs of meltage.
Old 02-22-2007, 05:45 PM
Cool
16500- P0116
Engine Coolant Temp.Circ Range/Performance
Old 02-22-2007, 05:47 PM
San Marcos, TX, USA
thanks.
Old 02-22-2007, 05:48 PM
manoverboard987's Avatar
Lurker Status Assumed.
Car: 2000 Jetta GLS 2.0L
Originally Posted by Alan Margosian
16500- P0116
I think that I saw a thread once where someone traced that code back to a faulty coolant temp sensor, but I could be totally wrong...
Old 02-22-2007, 05:51 PM
Cool
could well be...just wanted to give Fowvay his due for making this code reference guide possible. The gift that keeps on giving...
Old 02-22-2007, 05:53 PM
San Marcos, TX, USA
there is no meltage. Do you have any ideas why my fan might not be working properly??
Old 02-22-2007, 05:58 PM
Cool
There could be several possibilities as to the cause. I don't want to, without knowledge, have you checking 50 different components for causes. Someone will chime in soon with likely scenarios.
Old 02-22-2007, 06:02 PM
Cool
You can start using the search feature here to find pertinent threads. Here's one that refers to the coolant temp sensor that Manoverboard was mentioning:
http://www.newbeetle.org/forums/show...t=cooling+fans
CEL Code PO116 Advice? Lugnutx5 1.8 Liter Turbo 15 10-13-2006 08:11 AM
