Driver's door lock/opening problem - NewBeetle.org Forums
Old 02-24-2007, 12:48 AM
MrRadi8's Avatar
Paducah, KY,
Car: 99 GLS
Exclamation Driver's door lock/opening problem
The tale of the plastic clips on the windows breaking. 7 years past service date put it a week beyond when the passenger door failed. I just got done with the drivers door but now the door won't open.
You have to turn the lock and use the handle to get it to open. Also, the lock will not go down into the locked position. It will open from the inside, just not the outside without using the key.
Anyone???
Old 02-25-2007, 05:56 PM
MrRadi8's Avatar
Paducah, KY,
Car: 99 GLS
Nobody?
Great. I'm the only one to hose the door up fixing the stinking window problem.
Old 02-25-2007, 06:01 PM
2011 Honda Pilot EX-L
Car: white '99 2.0 GLS stick
Cool
I posted up a link to the window regulator repair/replacement process. If you didn't see it, I'll repost that link for you...
Old 03-04-2007, 05:33 PM
MrRadi8's Avatar
Paducah, KY,
Car: 99 GLS
I saw that but not anything about a problem with the lock or outside handle.
Interior light not switching on when opening door rawr Questions, Issues, Concerns, or Problems with the New Beetle 17 01-10-2012 11:27 AM
Driver's side door lock coming out DR.billZ The New Beetle Experience 9 10-12-2009 03:51 PM
Driver's Side Door Problem matone_05 Questions, Issues, Concerns, or Problems with the New Beetle 3 02-25-2007 07:11 PM
Cup Holder & Noise when opening driver's door Tacoma Questions, Issues, Concerns, or Problems with the New Beetle 1 08-26-2006 10:50 PM
Driver door lock problem tequilaiam Paint and Body 4 08-24-2006 09:26 PM
