2.0 Engine Codes - NewBeetle.org Forums
Old 03-19-2007, 02:30 PM
just another peon...
vicksburg, MS,
Car: 98 Red "Sport" - 2.0l Auto
Default 2.0 Engine Codes
In an information gethering effort, I'd like you 2.0 folks to reply here with your engine codes and if possible, if your VW has a secondary air pump/EGR. According to a pdf I found here: http://volkswagen.msk.ru/engine/aeg/...nb_general.pdf the AEG's all had the EGR system, but not the ABA or some BPY. I don't really and truly trust that info however and would like to find out what you other ORG'ers have under the hood.
TIA!
Old 03-19-2007, 07:29 PM
Car: 1998 2.0L 5 spd
AEG, AVH, AZG, BDC, BEV, BGD
My AEG has the sap, but I'm sure it doesn't have egr.
"There is no TEAM in I
Old 03-19-2007, 08:41 PM
vicksburg, MS,
Jian, If you have the SAP then you have an EGR (am I right guys?). Follow the output tube from the air pump, if it's like mine it ends at the EGR valve. Or at least the Ruskie's say it should..lol.
Old 03-19-2007, 09:11 PM
tdi's use egr(exhaust gas recirculation) to reduce emmisions.
The sap is used to reduce emmisions but it does not recirculate exhaust
what your calling the egr valve is the combi valve.
Old 03-19-2007, 09:41 PM
vicksburg, MS,
Ahhh ok cool, excellent. Thanks for the correction. So that's the infamous Combi Valve, hehe.
Old 04-06-2010, 05:04 AM
TIA!
the combi valve is located behind the cylinder head you'll need to remove the intake pipe that connects to the air filter. it is in a very tight place. to pull this out you ll' need to lift the car, and check under with a flash light close to where the exhaust manifold, you'll see the two little holes where you can stick an long extension with a allen tip key I think a 5m or 6m that way you can unbolt the valve. I was trying to unbolt it from the upper part but is not possible
I think that's the reason they have the little two holes on the air deflector plate. mine was full of carbon and the gasket was very bad I WAS getting the code P0411 and a lot of engine rattle. if this help but I don't see that many topics on how to pull this part out.
Old 04-06-2010, 12:10 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
TIA!
My '98 AEG has a SAP
My '99 AEG does not have a SAP
My NB Family...
Old 04-06-2010, 12:37 PM
My just sold 2000 AQY code 2.0 engine had a SAP
Our 2007 AZJ code (I think) 2.0 NB has a SAP (UK car hence us still having the 2.0 engine!)
Our cars:
2006 1.9 TDI PD New Beetle Convertible (UK car)
2007 2.0 New Beetle (UK car)
1958 1200 Beetle (multi show winning car)
2002 GLS 2.0L engine codes AVH & AZG Skoobahead 2.0 Liter Gas 2 01-22-2011 02:09 PM
Engine dies, wont start NO ERROR CODES bababooey 2.0 Liter Gas 6 09-02-2006 06:42 PM
Quick question on Samco TIP and engine codes Anaconda 1.8 Liter Turbo 3 08-27-2006 04:18 PM
Couple Of Engine Codes, Plz Help!! Zookie Questions, Issues, Concerns, or Problems with the New Beetle 8 11-30-2005 07:00 PM
Engine codes Skoobahead Questions, Issues, Concerns, or Problems with the New Beetle 5 11-16-2005 02:42 PM
