Most likely a bad temp sensor. My service writer said I should replace mine myself to avoid the $140 installation fee.
I think there's a how-to around here somewhere. Basically you'd need to make sure the engine has cooled off for a few hours, make sure you have a new O-ring seal for the new sensor, release the pressure in the coolant line by opening the cap on the reservoir, then replace the cap. It's just a little metal clip that holds the sensor on (it's under the engine cover) and then make sure you get the old seal out! As long as you've let it cool for a couple of hours and you remember to relieve the system pressure and replace the cap it should be really easy. Best of luck!
I'm J-Dawg, flyin' down the road in Paul McCARtney, the only Beetle in wings! Mi Bacca es Chewbacca! ![]() ![]() I'm one of those people. Whatever that means. |
He forgot to add .... new clip that holds it all together ... if you don't get one the one you have usually breaks when you take it out .... chances of that I have seen here are 3:1 if you don't get one. Total cost of the parts is around $28 ... I think, the sensor was around $6 when I did mine and the price went way up in the last year or so.
I'd like to bump this thread to the top. My dad just got a '99 GLS with only 32,000 miles. It belonged to an 81 year old man who hardly ever drove it.
He is having a similar situation. The only thing different is that his blue light will flash and also stays lit. Overall, the car is running smoothly. Does that also sound like a sensor problem as well? Thanks! Jonathan
Pics of Layla, my 1998 New Beetle http://newbeetle.org/forums/showthre...106#post303106 |
Yeah, mine would stay on, then go off for a few minutes, then come on again.
NOLA, after 2 changes I've never had a clip break, but it's good to know that's a possibility! Maybe I'll get one of those just in case. |
| Revo and Flashing Temp Light | vpkb1998 | Questions, Issues, Concerns, or Problems with the New Beetle | 21 | 03-15-2007 07:49 PM |
| BLUE Light, cold engine, Flashing | carkahlua | 2.0 Liter Gas | 5 | 09-12-2006 02:26 PM |
| 98 New Beetle flashing blue cooling system light | freddyjim | 2.0 Liter Gas | 3 | 04-23-2006 02:22 AM |
| Blue coolant light flashing? | DruzeTito | 1.8 Liter Turbo | 7 | 04-19-2006 12:12 AM |
| Flashing blue temp light | Shamrockez | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 12-21-2005 04:57 PM |
